Another shot in the dark... it may not be the APJ file that is broken, it
may be the individual XML files. Delete them! If the project does not
recreate them, then manually open the files one at a time and right click,
save current layout as...
HTH,
Larry Bettes
ADT, C3D & LDT/CD
(all 2007 with all SPs installed)
P4 - Dual Core 3.0 GHz, 3.00 GB RAM
nVidia GeForce 6800 GS AGP - 256 MB
Windows XP Pro, SP 2
"Corey A. Layton" wrote in message
news:5364674@discussion.autodesk.com...
Corey A. Layton wrote:
> when I try to set a pre-existing 2007 Project current,
> it crashes, and permanently breaks my installation.
if it helps,
(to anyone who's listening),
I *think* I know what I did to 'break' my Project.
1. I had no Project active.
2. I manually opened some dwgs (Constructs & Views) that are part of a
project (Project 'A')
3. I then set the Project 'A' active while the dwgs were still open.
The application just froze.
No opportunity to submit an error report.
Had to ctrl-alt-del>Task Manager>Applications>End Task to get out.
