Announcements
IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
hardware lock problem
3 REPLIES 3
221 Views, 3 Replies
Since I just added some ram to my PC I had to disconnect all peripherals
and hardware locks (ADST2 and 3DSViz3) to open it. Now, when I try to open
certain files with ADST2 it fails with "HARDWARE LOCK ERROR" message. If
I click on cancel button another message is shown: "FATAL ERROR: Please
re-install or replace the hardware lock for AutoCAD". I've already checked
the correct connection of the lock.
The 3DSViz3 hradware lock gives no problem!
Any suggestion?
Thanks in advance for any help
Arch. Fabrizio Prato
3 REPLIES 3
Change the order that the hardware locks are
attached. Make ADST2 the 1st one attached.
Since
I just added some ram to my PC I had to disconnect all peripherals and
hardware locks (ADST2 and 3DSViz3) to open it. Now, when I try to open certain
files with ADST2 it fails with "HARDWARE LOCK ERROR" message. If I click on
cancel button another message is shown: "FATAL ERROR: Please re-install or
replace the hardware lock for AutoCAD". I've already checked the correct
Any suggestion?
Thank you Harry, but ADST2 hardware lock has always been the first attached.
Should I really reinstall ADST2 ? I hope there is some less annoying
procedure, because the event of momentarily detach the locks is not so
rare.
arch. Fabrizio Prato
I had a similar problem with a third-party
application - it didn't find the lock but Autocad did....
Ended up downloading the latest driver for the
hardware lock (a sentinel) and it worked again - worth a try?
Khay.
Thank
procedure, because the event of momentarily detach the locks is not so rare.
