Try right-clicking on the sheet set node and "Refresh Sheet Set".
You can also try the cammand UPDATEFIELD and select the fields to update.
If this doesn't work, make sure that the drawing layout is actually a sheet in a sheet set.
Paul McArdle
Autodesk, Inc.
"Brian E. Goldman" wrote in message news:41750106_1@newsprd01...
I have a field in a on my Title Block the references the current sheet number for a sheet within a project. I have a total of 7 sheets and 1 is not updating. Why? I copied the field from another drawing to perserve the formatting, I did this with all of the sheets. Please help.
Brian
