IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
eddie57
550 Views, 3 Replies
Fatal Error
I am using autocad architectural desktop release 3 with the operating system windows 7.  When Attempting to open a file I get the following error:
FATAL ERROR:  Attempt to delete class 'AecDatabaseData' which still has registered descendants.
10/15/2012 at 10:13:47.292  Drawing: R:\Everyone\Plans - Year 37\SITE PLAN XXXX\Site plan XXXX.dwg
Anyone have any idea how to correct this? I cannot open up any of my files. The sample drawings in autocad open up just fine. Thanks in advance.
Eddie
3 REPLIES 3
pendean
in reply to: eddie57
Try using RECOVER command.
eddie57
Can the Recover function be used on a file that won't open?  If so, how is this accomplished?
Eddie
eddie57
in reply to: pendean
I tried to recover the file and I got the following message: Aecloader could not load requested module error Aecbase20.dbx.
Any ideas what is causing this?
