Anthony, You are a SAINT.
I have been wrestling with this for three weeks, trying to get some answers.
Thank you for a simple and effective fix.
Craig. 😉
"Anthony Catana" wrote in message
news:4C141DA0AF76026A9AF049561EB2A7D0@in.WebX.maYIadrTaRb...
> I had the same problem.
> You need to turn off compatability.
> Right click on the AutoCad.exe program and select properties. go to
> Compatibility and turn it off.
> ADT 2i works fine in XP Pro.
> "Craig Mochrie" wrote in message
> news:4E724BEC8BFB5E20D177668AB4B011AE@in.WebX.maYIadrTaRb...
> > Running ADT2 on XP pro, Installed it with compatibility with Win2000
> > If I attempt to load a previously saved drawing with Aec objects it
aborts
> > without warning.
> > Also if I attempt to initiate a new drawing with the Aec Arch template I
> get
> > the following message
> > Fatal Error: Attempt to delete class 'AecDatabaseData' which still has
> > registered dependants.
> > I am at a loss. I have uninstalled and re installed and am having no
> luck.
> > BTW If I use a more basic template or start from scratch it works ok
until
> I
> > use an Aec object, say a wall and then it jumps out without warning.
Also
> I
> > cannot use my system printer anymore, I get a Memory Allocation Error.
> > Please assist if you can,
> > Craig.
