Autodesk Architectural Desktop 2007 & Prior
0 Kudos
Post 1 of 6
Express Tools Not Working
805 Views, 5 Replies
09-05-2010 01:12 AM
I reloaded my older 2002 ADT to work on blocks some for a friend of mine that still uses it. I noticed that the Express tools aren't working and they would make it easier and quicker to finish the blocks. Does anyone remember that far back on what files or what not needed to loaded to make them work?
Robert
*Expert Elite*
299 Kudos
Post 2 of 6
Re: Express Tools Not Working
09-05-2010 06:40 AM in reply to: TheOnlyIDLeft
I am not certain it extends that far back, but as far back as I can remember the Express Tools are not installed by default with ADT.  You have to do a custom install and then find the check box that indicates that you want the Express Tools feature installed.  You may be able to go to Programs and Features in the Control Panel (or, depending on your OS, it may be something like Add/Remove Programs) and modify the installation to add the Express Tools feature without completely uninstalling ADT.
If you are certain that you have already installed them, try typing EXPRESSTOOLS at the Command: prompt to get the associated menu to load.
David Koch
0 Kudos
Post 3 of 6
09-05-2010 10:38 PM in reply to: David_W._Koch
Thanks for the reply. Well I did a full install with and got the Express Tools in the menus bar and  the toolbars for them. Just get an unknown command when I try to use them. I tried EXPRESSTOOLS in the command line and got the same "unknown command."
Any other thoughts?
Thanks again,
Robert
*Expert Elite*
299 Kudos
Post 4 of 6
09-06-2010 08:37 AM in reply to: TheOnlyIDLeft
Perhaps the folder in which the Express Tools were installed did not get added to your AutoCAD search path (Options dialog, Files tab, under the Support File Search Path node).  For a stand-alone installation of ACA 2011 that used all of the default file locations, I have this folder in my search path:
C:\program files\autodesk\autocad architecture 2011\express
Depending upon how you did your installation (and what version of ACA you are running, the Express Tools may have been installed in a different folder.  If you can find that folder, add it to your search path and see if that helps.
David Koch
0 Kudos
Post 5 of 6
09-07-2010 11:38 PM in reply to: David_W._Koch
Support File Search Path for the Express file was one of the frist things I checked on and it was there.
Any other thoughts.
Thanks again,
Robert
0 Kudos
Post 6 of 6
09-08-2010 12:49 AM in reply to: David_W._Koch
Hey David,
Thanks again for the replies, thoughts, and ideas. With your last thought about the Express file not added under the Support File Search Path I thought I'd try re-installing the link for the Express file and got a messagae about not having permission for use of them. So I decided that for some reason some of the files did not get installed. So I open up my disk and explored the supoport files and found a few files that did not get installed so I copied them over and now all is a go.
Thank again,
Robert
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
