IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
Express tool bars and palettes
3 REPLIES 3
302 Views, 3 Replies
Hello all,
My express tool bar icons show up as question marks. They are questions
marks even in the pull down menus.
I am unable to drag and dock my palettes - Tools Palette, Properties, Design
center. I cant move any of those.
Any input is appreciated.
3 REPLIES 3
Hi Decibel,
Try deleting the acetmain.mnr file and restart your application and see if that helps..
See this link:
http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=5784225&linkID=2476059
There is a small lock icon on bottom right had side corner(below the command prompt)-if that is set to lock, then you cannot move/dock your tool bars.
Hope this helps,
Shruti Harve
Application Specialist,
Ideate
Thanks Shruti,
That worked for the Express toolbar icons.
I still have the issue of dragging the palettes and toolbars. I cannot drag
and move any of the toolbars and pallettes.
wrote in message
news:5262531@discussion.autodesk.com...
Hi Decibel,
that helps..
See this link:
Hope this helps,
Shruti Harve
Ideate
Hi Decibel,
Did you check to make sure that the position of tool bars and palettes are not locked..i can;t think of any other reason why this could happen,
Shruti Harve
Ideate,Inc
