Announcements
IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
exploding but keep the clip
3 REPLIES 3
4420 Views, 3 Replies
It doesn't happen very often but sometimes it would be nice to explode a xcliped block while keeping the stuff inside the clip boundary and trimming/discarding everything outside the clip boundary. Is anyone aware of a routine to do this? Thanks!
3 REPLIES 3
Try BLOCK command, then EXPLODE. -- Dean Saadallah Add-on products for LT http://www.pendean.com/lt --
I've tried that, but when you explode the block you get the whole block showing up not just the clipped part. As an example, we have some building sections that we've xref'd into a sheet and then clipped to get just the details we want. We want to see if we can find an easy way of just getting the clipped part so we can add the details to our detail library without having to trim, erase, etc. the remainder of the drawing. Obviously, there are ways to get the job done but the operative word here is "easy" (translate as fast and mindless). Thanks again
3wood
You can try EXPLODEALL.vlx
3wood
CAD KITS
