Announcements
IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
Error loading AcStandards services and Failed to register DWS file support for eTransmit.Failed to
2 REPLIES 2
1476 Views, 2 Replies
Does any know what this means? Here's the start up list: Loading AEC Base...Failed to register DWS file support for eTransmit.Failed to register DWS file support for eTransmit. Loading AEC Base UI... Loading AEC Base GUI... Loading AEC Project Base... Loading AEC Schedule Data... Loading AEC Architectural Base... Loading AEC Architectural UI... Loading AEC Structural Base... Loading AEC Area Base... Loading AEC Dimensions Base... Loading AEC Utilities... Loading AEC Area UI... Loading AEC Structural UI... Loading AEC Schedule... Loading AEC Dimensions UI... Loading AEC Schedule Data UI... Loading AEC Layer Manager... Loading AEC Project UI... Loading AEC Annotations UI... Loading AEC Design Center UI... Loading AEC Project Palette... Loading AEC Publish UI... Loading AEC Schedule UI... Loading AEC Object Explode... Loading AEC Recipe Base... Loading AEC Detail UI... Loading AEC Detail Base...Regenerating model. Error loading AcStandards services -- Regards, --------------- Reid M. Addis Registered Architect Architectural Applications Specialist Granary Associates 411 North 20th Street Philadelphia, PA 19130 Ph. 215-665-7056 email: addis@granaryassoc.com
2 REPLIES 2
Never mind ;) I thought I'd "fix" my system this morning and ran Norton WinDoctor. Fixed it all right! Anyway, after repairing the registry from the Add/Remove programs option, things seem back to normal, whatever that is :) -- Regards, --------------- Reid M. Addis Registered Architect Architectural Applications Specialist Granary Associates 411 North 20th Street Philadelphia, PA 19130 Ph. 215-665-7056 email: addis@granaryassoc.com
will
I have been getting this a lot. This is in R2012, although I do have Civil 3D installed. Something is in my drawing that is causing AEC to load, which does, is known to, cause all sorts of issues:
Command:  INSBASE
Enter new value for INSBASE <6.4556,-337.0410,0.0000>: *Cancel*
Command: *Cancel*
Command: *Cancel*
Command: Loading AEC Base... Loading AEC Base Extended... Loading AEC Project Base... Loading AEC Schedule Data... Loading AEC Architectural Base... Failed to register DWS file support for eTransmit.Loading AEC Base UI...
Command:
One thing I am puzzled about is why setting the insertion base point shoudl demand load AEC!?
Hopefully Autodesk will fix this soon.
Regards
Will
"Do I need a dare of the hog!" Sir Henry at Rawlinsons End
