Autodesk Architectural Desktop 2007 & Prior
New Member
0 Kudos
Post 1 of 4
Editing doors sizes in the Tool Palettes
323 Views, 3 Replies
08-14-2012 05:40 AM
When a try to enter in a the height and width of the door in the Dimensions tab AutoCAD will not let me select them. It will highlight the number and stay the same. Where can I go to change the settings of this?
*Expert Elite*
298 Kudos
Post 2 of 4
Re: Editing doors sizes in the Tool Palettes
08-14-2012 07:45 PM in reply to: Cubby2012
Is the tool palette on which the tool is located read only/locked?  If so, you will not be able to edit the tool without making the palette editable.
Is the tool or the palette on which the tool resides refreshable from a tool catalog?  If so, you will not be able to edit the contents unless you temporarily make the tool/palette non-refreshable.  After editing the tool's properties, you will need to update the source tool in the tool catalog (assuming you have write authority to do so) before resetting the tool/palette back to refreshable.  (If you reset the tool/palette back to refreshable without updating the source tool in the tool catalog, the refresh that takes place when you turn refreshability back on will reset the values back to the previous values.)
David Koch
New Member
0 Kudos
Post 3 of 4
08-15-2012 04:11 AM in reply to: David_W._Koch
I am not sure if the palette is read only / locked. How can I check on that? Brad Westfahl Architectural Designer brad.westfahl@corriganscbs.com EMAIL TEST-12012 Best of The Bay Finalist-5 PH. 920.336.2588 EXT. 111 CELL. 920.371.2709 FAX. 920.336.4052 4424 Dickinson RD. De Pere, WI 54115 www.corriganscbs.com
*Expert Elite*
298 Kudos
Post 4 of 4
08-15-2012 05:44 PM in reply to: Cubby2012
Look at the bottom corner of the palette, on the tab side.  There will be a lock icon if the palette is read only.  There will be an icon with two arrows in a circular pattern if the palette is refreshable from a tool catalog.
David Koch
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
