Announcements
IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
235 Views, 3 Replies
Edit Slab
I made a countertop out of a slab & cut a hole for the sink.
Now how do i Radius the corners ?
Under edit slab edge i don't see any selection for radius corners & could'nt
find it in help.
3 REPLIES 3
slabs will cut to plines.
"desgnr" wrote in message
news:5552733@discussion.autodesk.com...
find it in help.
Agree, use a polyline, draw lines and chamfer them with the radius you need, then conver them into polylines... then you will have a closed polyline.... then select the slab, and cut the hole using the polyline.... and you will have the hole for your sink.. good luck...
If you're talking about a radius in section such as what you would see
with an undermount sink (and you really need that much detail), then you
should be able to do what you want with a slab edge style.
Unfortunately it may be problematic to make it look like you want in
plan after you're done though.
John
