sounds like you'd be better off using LDT... but since you're here... draw the contours as lines/plines and elevate them. then use either Viz or one of the free routines on the web to convert them into a mesh (my favorite is one called LV.LSP)... for property lines you'll just have to draw them the old fashioned way - enter a start point and specify distance and bearing as you go around the site.
