Do you mean that the ADT object is in the X-ref, but the hatching is in the
current dwg? Or do you mean that in the X-ref there is some hatching that
uses ADT objects as boundaries?
What about the ADT wall object that has hatching defined as part of the wall
style? For example, a concrete wall that has a concrete hatch pattern
between the two lines that represent the wall faces. Is that a problem?
Thanks for your help. Mark
"Matt Dillon" wrote in message
news:B0035B6E8EC8205BA0B3F7DDFCA7B048@in.WebX.maYIadrTaRb...
> John Rizzo hit it.
> Your problem is most likely associative hatches using ADT objects for
their
> boundaries. An example would be using walls as associative hatch
boundaries,
> but it can happen with other things as well. Go to the XREF's in which
this
> occurs and remove the boundary associativity. In the future, you can use
> BPOLY to generate the boundary and use the resulting pline as your hatch
> boundary. It isn't associative, but you won't get the problem you're
> currently experiencing either.
> HTH
> Please do not email me privately with technical issues
> Matt Dillon
> Assistant Moderator: Autodesk Discussion Forums
> http://www.dccadd.com
> "Mark Nienberg" wrote in message
> news:CB13D6F62FC7AA01895ACED220E1877C@in.WebX.maYIadrTaRb...
> > Yes. In fact we are using Arch Desktop 3.3. I posted here because it
> > wasn't obvious that it was related to the arch desktop features. Do you
> > know how to fix it? Thanks, Mark
> > news:4387EF1FFA1F0A90F45698BCAA4D871B@in.WebX.maYIadrTaRb...
> > > Do any of your files, including the XREF's, have objects that
originated
> > in
> > > Architectural Desktop in them?
> > > Matt Dillon
> > > news:74F5B6F5B722980462CC69E00CE5B2DD@in.WebX.maYIadrTaRb...
> > > > We are having a problem opening some drawings. It is hard to be
sure
> if
> > > it
> > > > is certain drawings or if it happens randomly, but here is what
> happens:
> > > > When opening the drawing the text window shows that the Xrefs are
> > > resolved,
> > > > then the AutoCad Express menu loads, then we get:
> > > > 1302 selected
> > > > Do you really want to do this?
> > > > If we respond with "N", then it says:
> > > > Everything has been undone.
> > > > But the message
> > > > repeats and we respond "N" again
> > > > and the whole process repeats another 5 or six times.
> > > > Finally, the _Help command is executed.
> > > > Closing Help will usually get us to the command prompt, but
> > > > shortly thereafter we get
> > > > Unhandled Access Violation Reading 0xffffff Exception at 654448a0h
> > > > Any ideas at all? Thanks, Mark
