Announcements
IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
Dim Text Override
5 REPLIES 5
lrizzolo
349 Views, 5 Replies
Dim Text Override
How do i find a dim text override in a drawing?
5 REPLIES 5
in reply to: lrizzolo
one way would be to click on a dimension and look to see if anything is in the text override box. If there is, you can compare the length with the measurement right about - they should match.
If you want to add text to the dimension, just add <> then your text in the text override box.
lrizzolo
Yes I understand that I can do this but I'm trying to check a large project (300,000sf) and this would take forever and not be cost affective. Anyone else have a suggestion or a lisp routine.
This lisp might do the trick.
Leo
wrote in message news:5791764@discussion.autodesk.com...
lrizzolo
Leo,
This is exactly what I needed. Works great.
Thanks so much.
Lee R
You're welcome...
Leo
wrote in message news:5791838@discussion.autodesk.com...
Leo,
Thanks so much.
Lee R
