Select it.. Right Click.. Add Selected.. then on the Properites Palette
you can see the shape it will add, at which point you can add another or
select a differnent shape from the drop down, if so desired, or cancel once
you have the info. I do agree that it should come in with the shape as the
block name but the work around work well.
ACote
wrote in message news:5789335@discussion.autodesk.com...
All,
Just a quick question:
Is there a way (in 2005) to make a detail component (or a detail component
that is dragged to a palette) come in with a standard block name...or is it
perpetually and always anonymous.
The problem I have is the steel shapes....I place them and I know the name
of what I placed. A few weeks down the road I go to check the shape for
proper size and the name is not the proper name but an anonymous. What to
do?
Thanks!
Drew
