IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
491 Views, 3 Replies
DETAILS (MENU)
Is there a easy one-step way to change the size (physical dimensions) of
some of the detail items..for instance the 6" batt insulation doesn't fit in
a 2x6 stud wall (it's only 5 1/2" wide) and will run into either the
sheathing or the drywall.
Paul Caruthers
3 REPLIES 3
Edit the AecMaterials.mdb with Microsoft Access. There are default tables in
which you can edit the widths and even add more choices, etc. It is located
in the following directory:
C:\Documents and Settings\All Users\Application Data\Autodesk\Autodesk
Architectural Desktop 2004\R16.0\enu\Support\AecDetails
AWSOME. THANK YOU---
"Rafael Alvarez" wrote in message
news:5996DE578A287E5943578C59FF1361A3@in.WebX.maYIadrTaRb...
in
located
Rehashing old stuff here:
I'm back on my own for now and have ADT 2004.  I would like to edit the AECMaterials.mdb file to add in proper batt insulation sizes.
I don't have MS Access, so instead I downloaded Open Office and am trying to edit it there.  I can see the 07-BATT-I table, can see the sizes, but can't seem to do anything with them.  I can't add, edit or do anything else except change the order in which I'm viewing them.
Any suggestions?
Joshua Tapp
