Announcements
IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
Demand load Xref's default
1 REPLY 1
554 Views, 1 Reply
I am connected to a network where more than one person is using the same Xref. However every time I open a new drawing, the demand load Xref's under options-open&save resets back to enable. I would like it to default to enable with copy so other people can use the same Xref at the same time.
1 REPLY 1
The XLOADCTL system variable is an Interger saved in the Registry. In order
to turn the demand loading on and open a copy of the reference file, this
variable must be set to 2.
Check your permissions - it's probably defaulting to 1 because you do not
have rights to make registry changes at this level.
Ariane
Americas Product Support
WW Support &
Services, Autodesk
Discussion Q&A:
href="http://discussion.autodesk.com">http://discussion.autodesk.com
style="BORDER-LEFT: #000000 2px solid; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px; PADDING-LEFT: 5px; PADDING-RIGHT: 0px">
I
time.
