IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
Cut out toilet partition for door
7 REPLIES 7
Message 1 of 8
635 Views, 7 Replies
I have a wall style for toilet partitions and a door style for the doors in
those partitions (taken from the OOTB toilet partition door style). I have
modified the door in properties to be 5'-10" to the head, and 1'-0" to the
bottom (which is what it is in the real world). This shows up correctly in
plan. However in elevation/model, the toilet partition displays under the
door, below the 1'-0" bottom. I kind of understand why this is happening,
but is there a way to prevent it from doing that? I want there to be
nothing below the door...
Thanks in advance
Andy
"Are You A Good Person?"
take the test -> www.GoodPersonTest.com
7 REPLIES 7
Message 2 of 8
A. Lawniczak wrote:
>I want there to be nothing below the door...
I poked around a this too. But I got lazy and just trimmed out the wall
and insert the partition door without an anchor. In reality this is
what's happening anyway I guess and I'm not likely to want to drag the
door around on the partition surface.
David Kurtz
Peckham & Wright Architects, Inc.
Columbia, Missouri
Message 3 of 8
You could replace the door panel with a block the correct size. Turn
off the display of the door panel in every display rep that matters (say
model and elevation) and on the others tab select the block to replace
it with. I'm attaching a half completed example.
John
John W. Mumaw
Timber Frame Designer
Lost Bent Woodworking & Design
john@lostbent.com
Message 4 of 8
try and use a door widow assembly.
"A. Lawniczak" wrote in message
news:4963028@discussion.autodesk.com...
Thanks in advance
Andy
Message 5 of 8
Hmm good idea. A DWA with a lower cell and frame that is "hidden" may
work well.
David Kurtz
Columbia, Missouri
Message 6 of 8
can you add a wall opening the same size as the door?
Howard T.
"David Kurtz" wrote in message
news:4964729@discussion.autodesk.com...
work well.
David Kurtz
Columbia, Missouri
Message 7 of 8
Corinthian
Yet another method.
Insert the door elevated 1'-0" above the threshold. Modify the floor line of your wall where the door is. (Draw a polyline at the bottom of the door opening and "Project to polyline")
Message 8 of 8
kelley.pearson
in reply to: Corinthian
Great suggestion. The Floor-Line projection works perfect! 🙂
