This is technically in the wrong discussion group, but this one gets more views...
Anywho, I work in a firm that does 99.9% custom residential. We use simple 2D drawings - lines, hatch, text, a couple of blocks, and an xref here or there - for our projects. We practically only use 1% of what ADT is capable of doing (we use ADT 2005, by the way).
We are now starting to dabble in a little commercial work. I get to be the guinea pig that has to learn how to use ADT (with no prior ADT experience, just regular AutoCAD). I have many questions, one of which has been (basically) answered, another can't be solved until we finally upgrade to 08, and a third question I now bring up.
This is probably really easy to do, but again, I have no idea how to use the ADT features.
I want to make a custom door tag (and probably a custom window tag eventually) that looks like the picture I attached. The out-of-the-box door tags don't look like the one my boss wants, so I have to make one that does. So my question is, how?
I tried hacking and chopping my way through one try, and it didn't work. I opened up one of the stock door tags to see if I could modify it. Either you can't or I didn't do it right. What I ended up doing was exploding it, seeing what attributes were what and where they went, making the shape I wanted, and placing the attributes back where they needed to go. Then I did WBLOCK (seemed like a good idea at the time) with prompts of a room name and door style. Boom. Thought I was done.
Unfortunately, I was wrong. Not only did I lose the ability to keep it the same scale/size as it originally was, I also lost the ability to click on the ADT door first and having it know which door I clicked (which I still don't know how to change those attributes). All my door tag does is work like a basic block that I can place, edit the scale, and enter my info in the prompts, thus losing every feature that the door tag originally was.
So, what am I SUPPOSED to do to make a custom door tag? And keep in mind, while being quite knowledgeable with the basics of AutoCAD, I have no idea how Desktop's functionality works. So bear with me on this one and explain, it if you can, with an abridged step-by-step process. Or, point me to a link of how to do it.
