IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
CTRL + P doesn't work.
3 REPLIES 3
mzagorski
2160 Views, 3 Replies
Anyone had the problem where CTRL+P doesn't work to open the print dialog... or CTRL+S doesn't work for save? Other shortcuts such as CTRL+O and CTRL+N do work fine.
Mike
3 REPLIES 3
in reply to: mzagorski
mzagorski wrote: > Anyone had the problem where CTRL+P doesn't work to open the print dialog... or CTRL+S doesn't work for save? Other shortcuts such as CTRL+O and CTRL+N do work fine. > > Thanks > > Mike nope.. All are fine here. If you DO have a tool palette focused it grabs the key input though. -- David Kurtz Peckham & Wright Architects, Inc. Columbia, Missouri
Do you have Windows standard accelerator keys enabled for the current profile? In the Options dialog, go to the User Preferences tab and see if that toggle is checked in the Windows Standard Behavior area in the upper left corner.
David Koch
Autodesk Discussion Group Facilitator
Is it a matter of it actually doesnt work or that the dialogue box doesnt appear. If this is the case set CMDDIA to 1.
