Hi Sara,
Were you set to Publish in the Foreground or the Background?
("backgroundplot" variable or Plotting tab of Options)
Did you access the Publish dialog from the Sheets tab> rt click menu>
Publish > Publish Dialog? If so, this is a known defect. Access the Publish
dialog via File > Publish instead and then load the Sheets.
Fitz
"slhill" wrote in message
news:21684736.1094054360205.JavaMail.jive@jiveforum1.autodesk.com...
> Did you ever resolve this issue? I just recently tried the publish dialog
box and sometimes it worked fine, but today and yesterday I had the same
problem (fatal error after 1st sheet) about five times in a row.
> Thanks, Sara
