Hi Robin,
Any chances that you can post the drawing files for us to try to duplicate
your problem? If you don't feel comfortable posting the files, you can zip
them up and email them to me at work: scott.reinemann@autodesk.com.
Can you also include how you xref'd the files in - attach or overlay. Also,
did you specify an insertion point/scale/rotation on screen or use
pre-specified values?
Scott
"Robin Capper" wrote in message
news:18ADCB1BC74E640C38500BFE2B7C1D60@in.WebX.maYIadrTaRb...
> Got the same thing on one work station today (three files) when xrefing an
> ADT/Acad bundle into a new file.
> The Xref Structure is generally (where > indicates xref level);
> 1 Electrical (2d acad - not Building Services)
> 2 > Fitting Layout.dwg (ADT MV Blocks mostly)
> 3 >> Building dwg (either 2d acad or ADT)
> 3 will xref to 2 ok and both 2 & 3 show no audit problems
> Then when is 2 xrefed into 1 get the error, but (now it gets tricky), only
> sometimes. After the error can only open 1 by doing a recovery and even
this
> will fail sometimes. Log off, shut down, clear out temp files etc seems to
> make no difference. Then like magic it all works for a while?
> Regards,
> Robin Capper
> Email; robin.capper@xtra.co.nz or (work) robin.capper@thewarehouse.co.nz
> "Scott Reinemann (Autodesk)" wrote in message
> news:F09C897453B8AA44FA1BD38B3639FCA9@in.WebX.maYIadrTaRb...
> > I'm interested in how you got the eUnknownHandle problem in the first
> place.
> > Do you remember what you were doing to the drawing before you got that
> > problem? Does recover correct the problem? Do you have any other
> or
> > 3rd party applications running?
> > If you can post the file to the customer files newsgroup, I'll take a
look
> > at it. If you can also include any additional information that might
help
> us
> > track down the cause of the problem, that would be great.
> > Regards,
> > Scott
> > "Jerry Logan" wrote in message
> > news:E0EEDA5D50B7553EA64C0805733194CB@in.WebX.maYIadrTaRb...
> > > I have a problem child dwg that I want to block out to a new drawing
to
> > fix
> > > a corruption. I have a ton of Xrefs in the drawing that when blocked
out
> > > won't come along with the drawing. What's the quickest and most sane
> > method
> > > for getting the xrefs back into the new drawing.
> > > I've run recover on the drawing and that doesn't seem to help
> > > AutoCAD error message:
> > > INTERNAL ERROR:
> > > !U:\global\src\coreacad\CORESRC\scandr.cpp@773.eUnknownHandle
> > > Jerry Logan
> > > Cottle Graybeal Yaw Architects, Ltd.
> > > Aspen, Colorado
> > > WWW: http://www.cgyarchitects.com
