I'm a little late coming into this, but I must say a few things.
Yes DTI does add a bit of code to the acad2000doc.lsp file. Uninstalling
will remove it. Or, if the file it tries to load has been deleted, it
harmlessly does nothing. You can check your MENULOAD, and if the DTI menu is
not loaded, there is no hidden "influence" anywhere.
The problem continued after Christopher uninstalled DTI, which means that
blaming DTI for the problem was unjustified. We have a lot of people using
our add-on and get very few reports of problems.
The DTI package has been tested and examined by Autodesk, in a effort to
find any problems. None were fiound, and it worked fine. I don't know if
they want this public, so I won't mention any names - he can chime in here
if he cares to do so.
I can understand that if problems arise, any third part add-on is a natural
cause of suspicion and a logical step is to try eliminating it. But I feel
the the language used by Reid Addis ("Get rid of DTI Tech's add on
program!") and his insistance on it being a problem is totally unwarrented
bad-mouthing.
Ken Krupa
DTI Technoloogies, Inc.
kkrupa@dtitech.com
Christopher Herr
wrote in message
news:40D30EB4A03F3488F6C00CFC0FB2C7DD@in.WebX.maYIadrTaRb...
> Reid,
> Send me the bill. .
> Re: the DTI tools, you mentioned that it adds a line to acad2000.lsp etc.
I
> looked in those files for anything added/commmented by DTI--didn't find
> anything. I'm wondering if I need to make sure those files are original
and
> unedited.
> Could you post the file back to cf? Maybe your editing has cleaned up the
> file.
> Any suggestions on other approaches to eliminate the DTI influence?
> for your help with this.
> C
> "Reid M. Addis" wrote in message
> news:DB9CD541CB362CC0F2F6C9DB11D4B136@in.WebX.maYIadrTaRb...
> > Nice file cabinets in 3d . I had some issues initially opening the
file
> > with a black drawing open, so I restarted AutoCAD, ran Recover, and I'm
> > editing your file right now! What should I charge per hour ?
> > Seriously, I see the D Sheet, B Sheet, and D Sheet (2) layouts, your
> > GBA+AIA Layer Key Styles, etc. Hey, thanks for all the shelving wall
> styles!
> > Not sure what's causing your problems? Are you sure you completely
> > eliminated DTI??
> > Regards
> > Reid M. Addis
> > Architectural Applications Specialist
> > Granary Associates
> > 215-665-7056
> > addis@granaryassoc.com
> > "Christopher Herr" wrote in message
> > news:5837D9F557C2B650050BF3FC8F6DF1A4@in.WebX.maYIadrTaRb...
> > > I uninstalled DTI tools, restarted, and still the same problem with
the
> > > file.
> > > I've posted it to cf under the subject ADT fatal error file.
> > > Cheers,
> > > Christopher
> > > news:DD6FDB756CF0351055B54C89CDAE1F64@in.WebX.maYIadrTaRb...
> > > > Get rid of DTI Tech's add on program!
> > > > See if you are still having those issues.
> > > > If not, get Rob Starz's stuff instead.
> > > > DTI usually adds a line of code to either the acaddoc or 2000 lisp
> > file??
> > > > I'd just plain uninstall it and see what happens.
> > > > Regards
> > > > Reid M. Addis
> > > > Granary Associates
> > > > 215-665-7056
> > > > news:D5208A6E47E7D690259BCFD6420C01FC@in.WebX.maYIadrTaRb...
> > > > > My text screen reads as follows when I open Desktop (not the
corrupt
> > > > drawing
> > > > > file)--any relationship?? The error lines??
> > > > > Regenerating model.
> > > > > QuikPik(tm) 2.06 -- Loaded (QUIKPIK to change settings)
> > > > > Copyright 2001 ManuSoft (http://www.manusoft.com) All Rights
> Reserved
> > > > > AutoCAD Express Tools Copyright © 2000 Autodesk, Inc.
> > > > > AutoCAD menu utilities loaded.
> > > > > Loading DTI Productivity Pack...
> > > > > Loading AecBase...
> > > > > Loading AecUiBase...
> > > > > Loading AecLayerManagerUI...
> > > > > Loading AecArchBase...
> > > > > Loading AecUtilities...
> > > > > Loading AecArchX...
> > > > > Loading AecScheduleData...
> > > > > Loading AecScheduleDataArch...
> > > > > Loading AecUiScheduleData...
> > > > > Loading AecArchXM...
> > > > > Loading AecDCArch...
> > > > > Loading AecStructureBase...
> > > > > Loading AecStructure...
> > > > > Loading AecSchedule...
> > > > > Loading AecUiSchedule...
> > > > > Loading AecAreaCalculationBase...
> > > > > Loading AecArchDACHBase...
> > > > > Loading AecAreaCalculation...
> > > > > Loading AecArchDACH...ERROR: Unable to expand the layer key
'wall'.
> > > > > ERROR: Unable to expand the layer key 'dimline'.
> > > > > ERROR: Unable to expand the layer key 'wall'.
> > > > > DTI Productivity Pack for ADT loaded. Version 1.51
> > > > > DTI macros for ADT loaded. *** Use MH (Macro Help) for listing
message
> > > > > news:B1FC77A2D9D8615DA0E879D6F7121A70@in.WebX.maYIadrTaRb...
> > > > > > I have a file that is consistently giving me Fatal Error:
> Unhandled
> > > > > Access
> > > > > > Violation Reading 0x0000 Exception at 649c935fh.
> > > > > > I have autosave set for every 5 minutes, and the autosave file
> gives
> > > me
> > > > > the
> > > > > > same error.
> > > > > > When I insert the file into a blank drawing, I get an Exception
in
> > > > > > ACBlock.arx ARX Command dialogue that reads Unhandled Exception
> > > C0000005
> > > > > > (Access Violation Reading 0x0000) at address 649B1953h.
> > > > > > When I do a partial open, unload xrefs, I get the Fatal Error:
> > > Unhandled
> > > > > > Access Violation Reading 0x0000 Exception at 649c935fh again. I
> get
> > > the
> > > > > > same error when I use the recover option.
> > > > > > There is a lot of time invested in this file. Mille Grazie for
> any
> > > > > > assistance.
