As David mentioned, if you lock your mview window, this problem should not
happen again. There is a chance, if you double click the mview window
(instead of the dtext) you might go to model space. (You may not notice
this, since you have zoomed in too much!)
To lock the mview window, select it while in pspace, right click, go to
properties and then select yes for Display Lock under the Misc section.
Nicholas Iyadurai
St Louis, MO
wrote in message news:5144012@discussion.autodesk.com...
Trust me to find some quirk that can't be reproduced anywhere else.
Honest - I'm not lying! I'm wondering if PICKADD has something to do with
it, because both of my concerns began about the same time? I didn't always
have the edit session explained here, throw me into model space.
