I started with two because our auditors wanted to use gross sf & our leases to clients are on a system where their suites are measured to the inside of the outside walls & to the midpoint of all interior walls. I originally had two space objects but with the upgrade to 2006 I was able to use one and select Gross, net and/or usable. It seemed to make sense to use gross & net.
