Announcements
IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
callout placement
2 REPLIES 2
242 Views, 2 Replies
callout placement
sometimes when i drag a view with a callout into a sheet via the pn i get the right sheet information but it is overlayed with a line of "#############" in addition to the sheet no and detail no. any suggestions how to fix this?
2 REPLIES 2
If it is overlayed it sounds as if you have two fields, one on top of the other within your callout block?
cc
that's wat it was thanks "calfcreek" wrote in message news:1527292.1097855049951.JavaMail.jive@jiveforum1.autodesk.com... > If it is overlayed it sounds as if you have two fields, one on top of the other within your callout block? > > cc
