IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
callout placement
2 REPLIES 2
241 Views, 2 Replies
callout placement
sometimes when i drag a view with a callout into a sheet via the pn i get the right sheet information but it is overlayed with a line of "#############" in addition to the sheet no and detail no. any suggestions how to fix this?
2 REPLIES 2
calfcreek
If it is overlayed it sounds as if you have two fields, one on top of the other within your callout block?
cc
that's wat it was thanks "calfcreek" wrote in message news:1527292.1097855049951.JavaMail.jive@jiveforum1.autodesk.com... > If it is overlayed it sounds as if you have two fields, one on top of the other within your callout block? > > cc
