IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
Better way to Post in Discussion Group?
16 REPLIES 16
Message 1 of 17
Pierre.LeBlond
207 Views, 16 Replies
What software are you using to view and keep track of Group Posts. Which RSS feed Should I Try.
Does everyone post there message in this little tiny very small Message Box?????
See attachment Message was edited by: PierreL
16 REPLIES 16
Message 2 of 17
in reply to: Pierre.LeBlond
It appears from your imagee that you are reading the newsgroups via the web.
I read them using the Outlook Newsreader. Works similar to my email. Outlook
Express has this feature also. As does Thunderbird and others.
wrote in message news:5236905@discussion.autodesk.com...
feed Should I Try.
Box?????
See attachment
Message 3 of 17
what is the Outlook Newsreader? I thought Outlook did not read newsgroups
so for a while I used both Outlook and OE, but finally I just use Outlook
Express for email and newsgroups.
Jack Talsky
"Chuck Sowers" wrote in message
news:5236942@discussion.autodesk.com...
feed Should I Try.
Box?????
See attachment
Message 4 of 17
Just web version via AOL for me -- works fine.
BOB
Message 5 of 17
Any Outlook Experts Here?
I am using Outlook Professional and want to Fix Newsgroup
Problem: last year i screwed around with outlook and accidently erased the outlook news command from Go as i was trying to create my own Pull Down Menu, i have re-installed outlook (Repair) Again But this news command is still not back???? What am I doing Wrong. I Don't want to go back to Outlook express.
Any suggestions welcome
Pierre
Just Foun This On Web I Am Going to try That:
Answer
Subject: Re: Newsgroups has disappeared 12/12/2004 7:08 PM PST
By: Russ Valentine [MVP Outlook] In: microsoft.public.outlook.general
To get the News command back, go back to the Programs tab in Control Panel |
Internet Options and change the default newsreader to Outlook Express. If
OE prompts you to make it your default newsreader the next time you launch
it, clear the "Always perform this check..." box and then click the No
button.
Russ Valentine
[MVP-Outlook]
chamar38 wrote:
> Hello,
> I just noticed that Newsgroups is no longer shown under the "Go" Menu item
> in my Outlook 2003. Nor is it shown when I try to customize my tool bar and
> add it. According to all instructions, it is supposed to be seen under the
> "Go" menu item Message was edited by: PierreL
Message 6 of 17
My outlook is usually promising. But I use Netscape and get a small ( my line returned there) box that is about 10 lines deep but will scrol as needed.
Message 7 of 17
PierreL,
I had this same problem before. I can't remember the fix right off, but I
found it on Microsoft's support site: http://support.microsoft.com.
Chuck
wrote in message news:5237157@discussion.autodesk.com...
express.
Pierre
Answer
button.
Russ Valentine
[MVP-Outlook]
chamar38 wrote:
> Hello,
> and
> "Go" menu item
Message 8 of 17
Jack,
Well, not exactly sure, but it looks just like Outlook Express, but without
any type of the email functions. It says Outlook Newsreader in the title
bar, but if you do a Help>About, it says Outlook Express. I think Outlook is
somehow just using the "engine" of OE , and is just accessing the Newsreader
function. I am using office 2003. If I remember correctly in older versions
of Office, Outlook would launch plain Outlook Express for the Newsgroup
reading task. That was a kinda 'hit-n-miss'.
Chuck
"JMT-02" wrote in message
news:5236958@discussion.autodesk.com...
Jack Talsky
feed Should I Try.
Box?????
See attachment
Message 9 of 17
Oh man?
Not getting much work done this morning I am trying to set newsgroup in Outlook. I have tried some of what they suggest on microsoft support like setting up newsgroup in Express Then it is suppose to work in Outlook? Can not find NNTP Account there asking in the Attach file:
Wondering if that's the solution?
Pierre
Message 10 of 17
Try this, go to the windows control panel - select internet options - then
the programs tab. From there set outlook express as your newsreader.
Then go back to outlook and see if news shows up in your go pulldown. If it
does work then make sure if oulook prompts you to make it your default clear
the "always perform this check..." box and select no.
Evan
Message 11 of 17
Evan
Got This Part Right So Far
I think all I Have To Do Now Is Find How to Include the newsgroup in Outlook NewsReader
Message 12 of 17
Searching for This solution now See Attachement
Almost There
Message 13 of 17
The simple way...
Go to http://discussion.autodesk.com
Select the link you want.
Select the newsreader link for the discussion area you want
to join.
It comes up in your default news reader set up in your
default web browser in Windows. You should be able to simply
Subscribe to it however your preferred news reader lets you
do so.
Repeat for every other discussion area you want to join.
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
Message 14 of 17
Thank Man
This took me 30 seconds to get a newsgroup in NewsReader
I was Trying to learn how to set NN...... Sever which was wasting my time
Pierre
Message 15 of 17
Account is: discussion.autodesk.com. Then you'll have to subscribe to any
groups that you are interested in. It might be easier to try Dean's method,
as listed in the reply below this one.
wrote in message news:5237416@discussion.autodesk.com...
Almost There
Message 16 of 17
I finally got my 3 Favorite ADT Newsgroup in Outlook News Reader But Now I Am trying to reply to a post reply is not working YET
Any Ideas where to set this Up
Strange Day Nothing Workings Today
Pierre
Message 17 of 17
Outlook > Tools > Customize > Switch to Command tab > Select Go in
Categories (Left Panel) > Select News in Commands (Right Panel) > Drag and
Drop News onto your Go Drop Down Menu.
Toan
express.
Pierre
Answer
button.
Russ Valentine
[MVP-Outlook]
chamar38 wrote:
> Hello,
> and
> "Go" menu item
