IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
Best format, resolution: scanned image for conceptual design phase?
3 REPLIES 3
116 Views, 3 Replies
I have some design sketches on flimsy that I want to scan and import
into ADT2 with the intent to do massing studies in conceptual design
phase using mass elements and groups.
Only four questions...
What is the best format, resolution, and color details ?
What freedom will I have to scale to real world units once inside of
ADT2 ?
Will scaling cause image quality to be unacceptable ?
Are there any online docs or tutorials on these matters ?
Thanks!
3 REPLIES 3
Tip on your 2nd question.
After inserting your scan, draw a line in real world units the length of one
of the scanned sketches (say 60' or whatever the actual length is to be).
Then use the ALIGN command to "align" the scanned sketch with the AutoCAD
line. This will scale and rotate your scan to the proper size.
Jim B.
"Mike Hutchinson" wrote in message
news:39A690E0.521CA2F1@bbsae.com...
> ADT2 ?
> Thanks!
Thanks for the tip... I was aware of the ALIGN commands capabilities with a move
and rotate but I was not aware of the scale as well.
Thanks again...
What about the other questions?
> Jim B.
> > ADT2 ?
> > Thanks!
Mike,
Just about any raster file can be inserted (pcx, bmp, tif, jpg, etc.). I
don't think color depth is that important. The higher the resolution the
better (to a point ... file size).
If you have the Architectural Desktop AOTC Training Guide, there is a
tutorial on the CD in a pdf format ... "pdf1-creating a massing study", it
goes through the steps of doing a massing study from a scanned image.
Jim B.
news:39A6ABEA.D4B47736@bbsae.com...
a move
> Thanks again...
one
be).
AutoCAD
> > Jim B.
> > > ADT2 ?
> > > Thanks!
