Mike,
> > What is the best format, resolution, and color details ?
Just about any raster file can be inserted (pcx, bmp, tif, jpg, etc.). I
don't think color depth is that important. The higher the resolution the
better (to a point ... file size).
>> > Are there any online docs or tutorials on these matters ?
If you have the Architectural Desktop AOTC Training Guide, there is a
tutorial on the CD in a pdf format ... "pdf1-creating a massing study", it
goes through the steps of doing a massing study from a scanned image.
Jim B.
"Mike Hutchinson" wrote in message
news:39A6ABEA.D4B47736@bbsae.com...
> Thanks for the tip... I was aware of the ALIGN commands capabilities with
a move
> and rotate but I was not aware of the scale as well.
> Thanks again...
> What about the other questions?
> Jim Borries wrote:
> > Tip on your 2nd question.
> > After inserting your scan, draw a line in real world units the length of
one
> > of the scanned sketches (say 60' or whatever the actual length is to
be).
> > Then use the ALIGN command to "align" the scanned sketch with the
AutoCAD
> > line. This will scale and rotate your scan to the proper size.
> > Jim B.
> > news:39A690E0.521CA2F1@bbsae.com...
> > > I have some design sketches on flimsy that I want to scan and import
> > > into ADT2 with the intent to do massing studies in conceptual design
> > > phase using mass elements and groups.
> > > Only four questions...
> > > What freedom will I have to scale to real world units once inside of
> > > ADT2 ?
> > > Will scaling cause image quality to be unacceptable ?
> > > Thanks!
