Hi again Scott. Last message today, I hope...
It appears if I copy the files to my local drive, I do not get any errors
opening them. I am not having any problems with any other programs and my
network. I do not know if this is related, but I can not get my mouse wheel
to bring up the osnap menu like it used to. If I set mbuttonsnap to 0 or 1
it only scrolls left or right. Thanks for any ideas you can give me, I'm
getting quite frustrated...
Dave
"Scott Reinemann (Autodesk)" wrote in message
news:17094549A71FC5A62F3893EA9B8ECAC3@in.WebX.maYIadrTaRb...
> Dave,
> You mention that you are upgrading one of your systems and that's the one
> you have problems with, but the drawing opens correctly on your old
system.
> What is your old system (OS and ADT), and what are you upgrading to (OS
and
> ADT)?
> Do you have any other Autodesk applications or 3rd party add-ons installed
> on your machine?
> Can you give us a little more information about your crash? Are you
opening
> the file from the Today window? If so, have you tried without going
through
> the Today window?
> Does it crash if ADT is not loaded? In Options, configure your Demand load
> ObjectARX applications to "Command invoke" and restart ADT and reopen the
> file.
> Does the file contain Xrefs? If so, have you tried hiding the xrefs to see
> if one of the xrefs is causing the problem?
> Any additional information would help us out greatly.
> SCott
> "Dave Pazyniak" wrote in message
> news:4B493FA7289D153D093CAD7A2F2B26DB@in.WebX.maYIadrTaRb...
> > Please see my previous post. the problem is getting worse, some files
can
> > not be opened at all from the one machine, but are fine from the old
one.
> > the error I receive when the file can not be opened at all is:
> > fatal error unhandled access violation reading oxfffff exception at
> > 6546a233h.
> > Please help. Thanks
> > Dave
