Autodesk Architectural Desktop 2007 & Prior
Active Contributor
john-jpa
Message 1 of 4 (332 Views)
Assign Multiple Tags at Once
332 Views, 3 Replies
06-10-2010 12:52 PM
We have our spaces set up. Is there a way to add all the room tags at once? Thanks...John
*Expert Elite*
David_W._Koch
Message 2 of 4 (326 Views)
Re: Assign Multiple Tags at Once
06-10-2010 03:41 PM in reply to: john-jpa
Tag the first Space, then use the Multiple option (look at the prompt on the command line) and select all of the Spaces to which you want add tags.
David Koch
Active Contributor
john-jpa
Message 3 of 4 (322 Views)
06-10-2010 03:44 PM in reply to: john-jpa
Thanks David...
Valued Contributor
cnewton
Message 4 of 4 (114 Views)
01-26-2012 12:51 PM in reply to: David_W._Koch
Thanks for that to the point answer.:smileyhappy:
A half hour of searching "help" netted me not a clue on how to do this.:smileymad:
Really a simple search "tag multiple spaces" Should get you to somewhere that tells you how to tag multiples spaces. Instead the frist result is for Attribute Definition Dailog Box, which has nothing to do with tagging spaces. Please somebody fix the help indexes before it too late!
Clint Newton III
Project Manager
Spillman Farmer Architects
Post to the Community
New Post
Need installation help?
