IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
Architectural Dimensions displayed as inches only
3 REPLIES 3
1106 Views, 3 Replies
Rather than have architectural dimensions displayed as feet and inches I want to display then as inches only.  How do you do this.
3 REPLIES 3
David_W_Koch
Set your Drawing Units to Inches, your Length Type to Fractional and the Length Precision to the appropriate fractional amount.  (You will not get the inches mark.)
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
mpresti
in reply to: David_W_Koch
You can add the inches mark in the suffix.
The problem with the inches suffix is that your angular dimensions come out in degree inches
