thanks for your reply. I'm still having difficulties creating a dynamic block and being able to insert it into another drawing without having to explode it.
I have the base entities that make up the block (lines, circle, hatch, attributes) and enter the BLOCK command, select the objects, pick a base insertion point, then check the 'Open in Block Editor' button. Hit ok, then enter the block editor and add the rotation parameter and rotation action. I close the editor and say 'yes' to save changes. I then save the file and try to insert that file into another one and the same thing happens. I need to explode the block in order to utilize the dynamic feature or edit the attribute. I must be missing something really basic. I've created blocks before, but these new dynamic feature are throwing me for a loop. Any further help would be appreciated. I have many blocks to add dynamic features to and would like to get a handle on them.
