I called Weyerhaeuser and was transferred to the regional rep. Left him a
message and he called back the next day. He sent me the CD ( I also tried
the download with no luck) installed it. It seemed to work great with one
gripe. I creates a ADT Icon on the desktop and it loads the program in, for
lack of a better term Weyerhaeuser Mode, a strange mode. All of my settings
were there It was just kind of annoying that in order to use their tools I
had to start ADT from their icon. I can't start it from inside of a current
session of ADT. There may be a way with a little hacking to reverse engineer
and find everything that needs to be loaded and then get it running in a
current session. I just haven't had time to play with it. As far as the
functionality of the program it works just the way you have described. All
of their doors, or at least a huge number of them, are in the program. You
can add lites, louvers, hardware, and select a price range on a scale of 1-8
I believe. You can also do up the specs for each of the doors placed in your
drawing.
It would be nice to see other manufacturers jump on this band wagon. I would
like to see plumbing fixtures, appliances, windows, etc. it would sure help
to make the model concept of drawing a reality.
"Cadmaniandevil" wrote in message
news:2631A203354DE2563DDC868896B37A20@in.WebX.SaUCah8kaAW...
> A while back I saw a beta demo of a door manufacture plug-in that was in
the
> works for ADT3 that allowed you to pick from a dialog a door straight from
> their actual product catalog with all the different options like lites,
> louvers, hardware, materials, finishes, costs, etc. It then would insert
> the door (ADT object door and style) exactly that way, 2d and 3d. It was
> incredible to see the hardware and lites/louvers in 3d!!! Just that part
> there is going to make my rendering life so much easier. But get this, it
> would even let you export the actual spec section for the door to MS WORD
> format to be cut and pasted into your main spec. WOW, it was very cool.
> And keep in mind, this was a very finished well working beta, not just
some
> test alpha with install/uninstall routines and finished graphic like it
had
> been in the works for quite some time.
> Anyhow, at that time I had heard that this was being done between AutoDESK
> and not just door manufacturers, but many type of other products and was
to
> be possibly a part of ADT3 or at least as plug-ins. Well obviously I
> haven't seen anything so far since its release, but with me being a VIP, I
> haven't received my copy yet so I don't even know if there is even
evidence
> of it in the programming yet.
> So if anyone has got their copy or has heard anything about this
> development, I'd love to hear from you.
