IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
ADT Walls IMPRECISE !!
7 REPLIES 7
Message 1 of 8
matthiast1
138 Views, 7 Replies
Hey there,
we are working on a larger project in ADT, and I keep finding walls that should be 100% orthogonal, but turn out to be just slightly rotated. I can tell by adding a construction line snapped to one corner point of the wall and then zoom in very closely on the other corner point on the opposite end of the wall.
Anyone know what that is, how this happens?
7 REPLIES 7
Message 2 of 8
in reply to: matthiast1
The only "imprecision" we've noticed is missing
"the click" just a little when using polar and otrack.  Maybe it's too much
coffee, but it's a recurring problem among all of our
people.
Message 3 of 8
a.c.childress
You should try putting "ortho" on or entering angles on the command line. The error may be in reading the angle "readout" and the precision it is set for.
Message 4 of 8
a.c.childress
Also I just remembered this. If you are looking at the lines on your monitor and they are a different color, it may only be an apparant error. Some times different colored lines "break" pixles differently. Measure the distance from end point to end point of same length lines to check for sure.
Message 5 of 8
I have found wall that are off by less than 1/256
of an inch.  And I don't know why they're off. Could the Auto cleanups be
throwing it off?  error in the algorithm?
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Also
sure.
Message 6 of 8
That is most likely a drafting error, commonly referred to as an
OE.
AutoCAD/ADT precision is excellent, except for limitations your
drafter imposes such as eye-balling and setting UNITS
incorrectly.
A simple test: re-draw it again, correctly, using all the
precision tools provided, then compare it to the original (just
like your review): bet they don't match up since the first was
not drawn correctly.
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
Message 7 of 8
What you lack in tact you certainly make up for in enthusiasm, Dean. I
agree on this one, though.
Message 8 of 8
Dean Saadallah
