IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
ADT 3.3 to SKETCHUP
3 REPLIES 3
233 Views, 3 Replies
ADT 3.3 to SKETCHUP
We have Sketchup 3.0 and I would like to transfer the Drawings from AutoCAD/ADT to Sketchup. Sketchup seems NOT to want to read ADT smart objects. I guess Sketchup only reads AutoCAD 2D, 3D extruded entities.
The problem is that we always, bind XREF, explode AEC entities, flatten the object, save the drawings then IMPORT them into Sketchup as 2D then we extrude and redraw 3D element in Sketchup.
I would like to know if there is a way to keep our 3D models drawn using ADT walls, doors, windows, etc and import them into sketch up. Is there a way, a service pack, a utility? It is counter productive to redo the work in sketchup. (Don't suggest that I should use VIZ or MAX or FORM Z please)
Kevin
3 REPLIES 3
Sketchup does not read ADT entities: they have not licensed it from
Autodesk.
Also, Sketchup in not an Autodesk product: you will have to consult the
authors for tips and ideas beyond what you have explored to date.
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
Have you looked at Autodesk Architectural Studio?
David Koch
Member of the Autodesk Discussion Forum Moderator Program
Do your AECEXPLODE in a "3D view". This should retain the 3d portion of the
objects.
Reid M. Addis
Registered
Architect
Architectural Applications Specialist
Granary Associates
411
North 20th Street
Philadelphia, PA  19130
Ph. 215-665-7056
email:
href="mailto:addis@granaryassoc.com">addis@granaryassoc.com
