IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
ADT 07 - DOOR SCHEDULES
5 REPLIES 5
pcaruthers
171 Views, 5 Replies
What is the best way to remove a door/opening from a schedule that is attached to an xref'd dwg........
And for that matter, what is the way to select items for this schedule......I go through this evertime. I can't select doors in the destination drawing, and I can only select the x-ref itself and I get it all........
Paul Caruthers
5 REPLIES 5
in reply to: pcaruthers
filter for Classification Assignments via the 'Applies To' setting in the
AEC Schedule Style definition....
pcaruthers
so you just give those items you don't want scheduled a classification and it's filiter out, is that correct?
Paul
Actually I usually filter *for* an explicit Classification Assignment.
(I don't think that you can do an inverse filter in ADT?)
Another option is to filter for a Layer Wildcard(s).
This is done in the Object Properties of the Schedule Object.
pcaruthers
very cool, thanks for the help.
Paul
Hi All,
I am conducting a course on the topic of using Classifications in ADT for
Schedules as an AUGI ATP course. Please sign up for the class if you are
interested. The class just started this week. You must be a member to
register for the course. Membership is FREE!
www.augi.com
Schedule of Classes:
http://www.augi.com/education/schedule.asp?page=292
John Herridge, AIA
wrote in message news:5169182@discussion.autodesk.com...
all........
Paul Caruthers
