IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
2008 Wall cleanup on sheets
0 REPLIES 0
Message 1 of 1
174 Views, 0 Replies
We are still using 2006 but will probably upgrade to 2008 when it gets
here. (couldn't install 2007 as our Ricoh printer took too long to
update drivers...).
So, has 2007 or 2008 solved the issue where multiple xrefs on the same
level interfere with each others walls when added to a sheet? You know,
becuase they just stack everything at 0,0 or whatever when added to a
sheet and the wall cleanup info interfered with other xrefs..
0 REPLIES 0
