Announcements
IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
Message 1 of 9
CTREVIZO
197 Views, 8 Replies
2007 RIZ RENDER
AS I BEGAN WORKING ON A PROJECT I TIRED TO LINK TO VIZ RENDER (FILE>>LINK TO AUTODESK VIZ RENDER...)TO ONLY FIND OUT IT WILL NOT START..ON THE COMMAND LINE IT COMES UP......"_VizRender Unknown command "VIZRENDER". Press F1 for help." DID I MISS A STEP ON THE SET-UP?
8 REPLIES 8
Message 2 of 9
in reply to: CTREVIZO
did you install viz render?
wrote in message news:5142726@discussion.autodesk.com...
Message 3 of 9
CTREVIZO
I THOUGHT IT WOULD AUTOMATICLY.
Message 4 of 9
no, I noticed on my install yesterday that I had to add it (along with
express tools) during the custom install.
~~Eric
Message 5 of 9
CTREVIZO
thanks for the info.
Message 6 of 9
Remember you don't need to do a re-install..just go to Add/Remove
programs>ADT2007>Change and add the features you forgot on original install.
~~Eric
Message 7 of 9
Makes you wonder why viz render isn't installed bu default. It seems the express tools are not part of the default install either???
Message 8 of 9
Express tools are removed from the typical install because of known issues
with the use of express tools. More information can be found here. TS84871
http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=5543312&linkID=2476435
Jeff Hanson
Autodesk Product Support
Building Solutions Division
Manchester, NH
_____________________________
wrote in message news:5143657@discussion.autodesk.com...
Message 9 of 9
I suppose the thinking was that anyone who had not already learned VIZ Render would likely use the new-and-improved rendering tools in AutoCAD. Doing a custom install is not really all that hard - even an architect can do it. If you have already installed, follow the suggestion in the previous post about installing additional components, rather than unistalling and reinstalling.
David Koch
Autodesk Discussion Group Facilitator
