A360 Forum
Welcome to Autodesk’s A360 Forums. Share your knowledge, ask questions, and explore popular A360 topics.
Revit file error
17 REPLIES 17
Message 1 of 18
tadasb
448 Views, 17 Replies
Revit file error
Hello, I uploaded a revit 2014 file and I get the error: Translation failed. What may cause this error?
17 REPLIES 17
Message 2 of 18
Swathi_Vadlamani
in reply to: tadasb
Apologies for the inconvenience. Can you please send the permalink of the revit file? You can get the permalink from Share - Permalink option. Or please do email me the file at swathi.vadlamani@autodesk.com or add me to the project where the file has been uploaded.,whichever is most convenient to you. We will make sure to see what has caused the error. Waiting to hear from you soon. Thanks!
Swathi Vadlamani
Autodesk 360 Web
Message 3 of 18
I talked to Swathi today an it sounds like your problem was resolved. We are still digging into it to see what the problem was. But please do post again if you have other issues with Revit files.
Thanks!
Scott Reinemann
Revit Development
Scott Reinemann
Revit Development
Message 4 of 18
ukdxb012
in reply to: reinems74
We too have had similar issues on first upload but if you try again, generally it works.
Duncan
Duncan Brannan
UK/EMEIA CAD Operations Manager
Twitter | LinkedIn
Message 5 of 18
Swathi_Vadlamani
in reply to: ukdxb012
Thanks for the info Duncan! We will look into the issue why the first upload preview is failing in most cases.
Swathi Vadlamani
Autodesk 360 Web
Message 6 of 18
Getting the same issue.
I can upload the Revit file, but the preview never gets generated.
Today I deleted my previous file upload, and re-uploaded. The preview is still generating, but it doesn't look good that it will finish.
Message 7 of 18
Mary_Morse
in reply to: Chad-Smith
Hi Chad,
Can you please give me more information on the upload failure?  What OS are you using, and what size is your .rvt file?
Mary Morse
Sr Manager, A360 Customer Success
Message 8 of 18
KyleB_Autodesk
Chad,
Also, have you verified that a simple test model works fine? I'd like to isolate the problem to the specific model you are testing.
-Kyle
Kyle Bernhardt
Director
Building Design Strategy
Message 9 of 18
Chad-Smith
in reply to: Mary_Morse
Here is a screen capture of the error.
Running on Windows 7.0 + SP1, Chrome browser Version 35.0.1916.153.
The size of the file is 23mb.
I will forward yourself and Kyle a PM of the permalink to the uploaded file.
I do have an even smaller model which did upload and translate.
My initial thoughts are that it looks really good! I have some comments which I will post to another thread.
Message 10 of 18
KALH
Same issues as others first upload failed Revit 2015 Model approx. 19MB
W7 Pro x64 SP1 - Chrome 35.01916.xxx - Revit 2015 UR3
Sent a permalink to Swathi by email
Most of the model is missing I only see the roof as shown below...
Thanks to fix this! And happy 4th
A360 Services Early Adopter
Message 11 of 18
KyleB_Autodesk
@Chad I took a spin through that model and there's nothing obviously wrong with it. I've logged a bug with our translation team to trace the point of failure.
Thanks for posting up here, the variability in Revit models was always bound to result in translation failures we need to fix, so you've helped us find a new issue.
-Kyle
Kyle Bernhardt
Director
Message 12 of 18
KyleB_Autodesk
in reply to: KALH
@Anonymous If you have a default 3D view (named "{3d}") in the Revit model already, can you post a screen grab of what it looks like?
-Kyle
Kyle Bernhardt
Director
Message 13 of 18
KALH
in reply to: KyleB_Autodesk
I believe I did already but here it is again:
Message 14 of 18
KyleB_Autodesk
in reply to: KALH
Thanks, it wasn't clear that screen cap was from the default 3D and not another 3D view in the Model. Looks like you have a translation failure. Best bet is to share it with us via Autodesk 360 and we can investigate. Invite kyle dot bernhardt at autodesk dot com and we can go from there.
Kyle Bernhardt
Director
Message 15 of 18
KALH
I already invited Swathi but I can invite you as well...
Message 16 of 18
KALH
Any luck fixing the issue?
Thanks for taking the time...
Message 17 of 18
KALH
in reply to: KALH
We can close the ticket - I found and corrected the issue.
the {3D} view was somehow croped to the roof- I had to detach the Revit model from Central and go back to this view that is only created on a detached file (stand alone). A-14.png
Message 18 of 18
Bud_Schroeder_ADESK
in reply to: KALH
Hi Kal,
Thanks for the update and I will forward this on to Kyle.
Bud Schroeder
AutoCAD Customer Council Beta Programs
Autodesk Inc.
Autodesk Beta Programs!
