I have just upgraded from AUD 2014 to AUD 2015. After converting my template file to 2015 my AUD feature symbols are being inserted at a reduced scale than before. All other blocks insert as expected. even when I insert an AUD feature as a regular block if inserts at the correct size. It happen only when inserting an AUD feature, ie pole, vault, transformer, etc.
Very frustrating. Any ideas. My audsymbolscale is set to 1. Not sure where else to look. All setting from in 2015 seem to be the same as they were in 2014.
Thanks in advance.
Jeremy
I know how to create and size the symbols. The problem is when I upgraded to 2015 is when things change. Everything works fine in the 2014 version.
Here are some suggestions for troubleshooting the problem:
The Utility Design forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
