AutoCAD Utility Design Forum (Read Only)
Welcome to Autodesk’s AutoCAD Utility Design Forums. Share your knowledge, ask questions, and explore popular AutoCAD Utility Design topics.
Parametric Blocks or Models
3 REPLIES 3
kulfi
747 Views, 3 Replies
If i need to make a block in AUD 2014 does it have a part builder like civil 3d. Please guide.
Kulfi
Electronics Engineer
Pind Saudi Arabia
3 REPLIES 3
in reply to: kulfi
hello Kulfi,
you should be able to use a regular autodcad block for most of your feature classes. Just add a style, hit the edit button and select the block you want to use.
JIm
kulfi
in reply to: kulfi
What is happening is that when i am moving to Industry Model in AUD 2014 and checking the properties for my 2d Model Block i am getting error and the program exits.
Kulfi
Pind Saudi Arabia
in reply to: kulfi
Kulfi,
you say the program exits, does it throw an unhandled exception error? Or does the program just go away with out any warning?
If it is either of these cases you should call AUD support because there is something wrong with the program itself.
Jim
”Boost
”Tips
Need installation help?
New Utility Design Category!
The Utility Design forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
