We are using the AUD 2009 and at the time of launching the AUD, we are getting the below error...
Application does not support just-in-time (JIT)
debugging. See the end of this message for details.
************** Exception Text **************
System.UriFormatException: Invalid URI: The format of the URI could not be determined.
at System.Uri.CreateThis(String uri, Boolean dontEscape, UriKind uriKind)
at System.Uri..ctor(String uriString)
at Autodesk.InfoCenter.CommunicationCenter.PopulateContents(ResultItemCollection& contentCollection, ICommCntrChannel channel)
at Autodesk.InfoCenter.CommunicationCenter.GetContents(ResultItemCollection& channelContents)
at Autodesk.InfoCenter.CommCntrSource.InitCommunicationCenter()
at Autodesk.InfoCenter.PaletteMgr.get_CommCntrSrc()
at Autodesk.InfoCenter.PaletteMgr.LoadCommCenterSources()
at Autodesk.InfoCenter.PaletteMgr.InitCommCenter()
at Autodesk.InfoCenter.PaletteMgr.InitSources()
at Autodesk.InfoCenter.PaletteMgr.FirstInvoke()
at Autodesk.InfoCenter.PaletteMgr.OnAppIdle(Object sender, EventArgs e)
at System.Windows.Forms.Application.RaiseIdle(EventArgs e)
at Autodesk.AutoCAD.ApplicationServices.Application.OnIdleWinForms()
at Autodesk.AutoCAD.ApplicationServices.Application.OnIdle()
How do I disable the CommunicationCenter in AUD 2009?
Please help.
jagwaran,
Not sure if you ended up getting this solved in past four weeks but since no further posts either way, I might as well try to reply. For what it's worth, that's a Autocad Map issue not AUD per se, but they're all of a piece for you so I understand. Below is a link from two weeks ago about this issue where they suggest fixing in the registry, it's meant for more recent versions of Map and I'm not sure if it's correct or applies to AUD/Map 2009 (I've uninstalled everything pre-AUD 2012 so I can't check to see if this is right. Good luck! ...
- Charlie
Plannedscape
The Utility Design forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
