AutoCAD Utility Design Forum (Read Only)
Welcome to Autodesk’s AutoCAD Utility Design Forums. Share your knowledge, ask questions, and explore popular AutoCAD Utility Design topics.
Data Connetion
1 REPLY 1
kulfi
761 Views, 1 Reply
Data Connetion
Can any one tell me how to establis data connection.
Kulfi
Electronics Engineer
Pind Saudi Arabia
1 REPLY 1
bill.dhimitri
in reply to: kulfi
Hi Kulfi,
Use the MAPCONNECT command to establish a connection to a data source.  The command works the same way in both AutoCAD Utility Design and AutoCAD Map 3D.  Documentation for this command can be found with your installed product. You can also find the documentation on line.  For example:
http://docs.autodesk.com/MAP/2014/ENU/filesMAPLRN/GUID-A6304264-F4A9-4391-AC0D-4ECB568E9639.htm
Bill Dhimitri
”Boost
”Tips
Need installation help?
New Utility Design Category!
The Utility Design forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
