AutoCAD Utility Design Forum (Read Only)
Welcome to Autodesk’s AutoCAD Utility Design Forums. Share your knowledge, ask questions, and explore popular AutoCAD Utility Design topics.
customize poles
2 REPLIES 2
zzffxx
645 Views, 2 Replies
customize poles
Is it possible to create my utility poles, for example, towers?  AUD provides too few types of features to meet my applications.
thanks.
2 REPLIES 2
jpab
in reply to: zzffxx
You can create a new feature class for any structure or line object that you need.
check the AUD help file, search using Create Feature Class, this will show you how to create a tower pole. Now you will have to use the  Infrastructure Administrator program to do it, but that program can be installed as part of the AUD install. the main reason a Tower pole wasn't a part of the initial AUD feature classes is because AutoDesk pretty much just create feature classes for the RUS standard objects and a Tower isn't use much if at all in standard distribution design.
I don't use AUD any more and really haven't since AUD2009, but i hope this helps
Jim
zzffxx
in reply to: zzffxx
Thanks, jpad. I'll be try it.
”Boost
”Tips
Need installation help?
New Utility Design Category!
The Utility Design forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
