AutoCAD Utility Design Forum (Read Only)
Welcome to Autodesk’s AutoCAD Utility Design Forums. Share your knowledge, ask questions, and explore popular AutoCAD Utility Design topics.
AUD Line Lengths
5 REPLIES 5
heberpower
2265 Views, 5 Replies
AUD Line Lengths
Me again, hey does any body know why my line lengths are wrong in AUD? If I list a line using the "LIST" command the length is correct, when I use the "AUDINFO" command the lengths are incorrect. For expample I just listed an underground primary line that measures 134.78 Meters using the standard "LIST" command. When I use AUDINFO I get a measurement of 5586. Any help would be great!
Thanks in advance.
5 REPLIES 5
heberpower
in reply to: heberpower
After some more digging I have discovered that the measurements are off by exactly 40....Please help.
heberpower
I have figured out more of my problem but not all...when I invoke the UDSDWGSTAT command I get this result:
The scale of this drawing is 40 and model number 0.
I need to know the command to change the 40 to a 1...Anyone?
AUDINFO calculates additional wire length based on the connected structure, and the value set in configuration.
Make a note of the structure connected to the wire, then look in the configuration:
AUDCONFIG > Facilities > Structure
On the block name, "Additional Wire" will likely be 40.
Jeff Paquette
Data Management Support Specialist
Autodesk, Inc.
CornDawg
Well Heberpower,
Did this help?
Thanks Corn
heberpower
I figured ot out...Somehow SETVAR "useri1" was set to 40, changed it to 1 and everything is good now.
Thanks for all your help!
Heber Power
”Boost
”Tips
Need installation help?
New Utility Design Category!
The Utility Design forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
