Hi I'm new to AUD. Just wondering how I can set the cover depth for new underground ducts?
The design surfaces have been created. When I draw underground, the ducts seem to be around 1.5 metres below the surfaces. We'd like to change the cover to 0.6 metres. Can anyone tell me how to do that please?
Thanks.
David
Solved by dave.w. Go to Solution.
Thank you very much for your reply Dave.
The command AUDTRANSITIONPOINT can almost solve my problem, but it is a little bit different from what I expected. We'd like the duct to be, say 0.6 metres strictly from the surface in accordance with the terrain. When I draw a straight duct in AUD, it seems that I can only offset the depth at the start and end insert points. However there should be a lot of points (vertical changes) along the straight line. We hope the line can be draped onto the suface to get the points then they can be offset 0.6 m below the surface continuously throughout the corridor.
Can you tell me is there any way I can do that in AUD please? Or can I create a duct from an object like 3d polyline in AUD?
Thanks.
David
Thanks Dave. Your reply is great helpful.
One more question about the surfaces. We have several different layer of surfaces at the same place, for example exisitng ground, design ground, design pavement layers etc. When I attach the surfaces file as a xref to the AUD file, how can I define which surface to use for AUD design?
Thanks.
David
The Utility Design forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
