2017/1/10:21:33:32 sevcan SEVCAN === Setup started on SEVCAN by sevcan ===
2017/1/10:21:33:32 sevcan SEVCAN Path_Length: 162
2017/1/10:21:33:32 sevcan SEVCAN Current Directory C:\Autodesk\AutoCAD_2017_English_Win_32_64bit_Trial_en-us
2017/1/10:21:33:32 sevcan SEVCAN Launch
2017/1/10:21:33:32 sevcan SEVCAN CommandLine /PK 001I1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_English_Win_32_64bit_Trial_en-us_Se..."
2017/1/10:21:33:32 sevcan SEVCAN Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2017/1/10:21:33:42 sevcan SEVCAN === Setup ended ===
2017/1/10:21:34:44 sevcan SEVCAN === Setup started on SEVCAN by sevcan ===
2017/1/10:21:34:44 sevcan SEVCAN Path_Length: 162
2017/1/10:21:34:44 sevcan SEVCAN Current Directory C:\Autodesk\AutoCAD_2017_English_Win_32_64bit_Trial_en-us
2017/1/10:21:34:44 sevcan SEVCAN Launch
2017/1/10:21:34:44 sevcan SEVCAN CommandLine /PK 001I1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_English_Win_32_64bit_Trial_en-us_Se..."
2017/1/10:21:34:44 sevcan SEVCAN Current Directory C:\Users\pc\AppData\Local\Temp\_AI64EA.tmp
2017/1/10:21:36:39 sevcan SEVCAN === Setup ended ===
2017/1/10:21:34:46 sevcan SEVCAN === Setup started on SEVCAN by sevcan ===
2017/1/10:21:34:46 sevcan SEVCAN Path_Length: 162
2017/1/10:21:34:46 sevcan SEVCAN Current Directory C:\Users\pc\AppData\Local\Temp\_AI64EA.tmp
2017/1/10:21:34:46 sevcan SEVCAN Launch
2017/1/10:21:34:46 sevcan SEVCAN Download Play SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUPMARK...
2017/1/10:21:34:46 sevcan SEVCAN Download Complete SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUPMARK...
2017/1/10:21:34:46 sevcan SEVCAN Download Play SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUP_x64...
2017/1/10:21:36:38 sevcan SEVCAN Download Complete SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUP_x64...
2017/1/10:21:36:38 sevcan SEVCAN Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\pc\AppData\Local\Temp\_AI64EA.tmp\Setup\AcSetup.dll
2017/1/10:21:36:38 sevcan SEVCAN Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/1/10:21:36:39 sevcan SEVCAN PageOpen LaunchDialog
2017/1/10:21:36:48 sevcan SEVCAN PageOpen LicenseDialog
2017/1/10:21:36:48 sevcan SEVCAN PageOpen ProductInfoDialog
2017/1/10:21:36:48 sevcan SEVCAN PageOpen ProductSelectionDialog2
2017/1/10:21:36:54 sevcan SEVCAN PageOpen FullProgressDialog
2017/1/10:21:36:55 sevcan SEVCAN Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARK...
2017/1/10:21:36:55 sevcan SEVCAN Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARK...
2017/1/10:21:36:55 sevcan SEVCAN Download Play DOTNET46 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/DOTNET46....
2017/1/10:21:38:30 sevcan SEVCAN Download Complete DOTNET46 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/DOTNET46....
2017/1/10:21:38:30 sevcan SEVCAN Installing .NET Framework Runtime 4.6: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\dotNetFramework\46\dotNetFx46_Full_x86_x64.exe" /q /norestart
2017/1/10:21:39:19 sevcan SEVCAN Install .NET Framework Runtime 4.6 Failed Failure is ignored, Result=1603
2017/1/10:21:39:19 sevcan SEVCAN Download Play UCRT http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/UCRT_x86....
2017/1/10:21:39:23 sevcan SEVCAN Download Complete UCRT http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/UCRT_x86....
2017/1/10:21:39:23 sevcan SEVCAN Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2017/1/10:21:39:23 sevcan SEVCAN Install Universal C Runtime (KB3118401) Succeeded
2017/1/10:21:39:23 sevcan SEVCAN Download Play VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2017/1/10:21:39:31 sevcan SEVCAN Download Complete VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2017/1/10:21:39:31 sevcan SEVCAN Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\pc\AppData\Local\Temp\vcredist_x86_2015.log
2017/1/10:21:39:33 sevcan SEVCAN Install Microsoft Visual C++ 2015 Redistributable (x86) Succeeded
2017/1/10:21:39:33 sevcan SEVCAN Download Play VCREDIST2015X64 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2017/1/10:21:39:43 sevcan SEVCAN Download Complete VCREDIST2015X64 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2017/1/10:21:39:43 sevcan SEVCAN Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\pc\AppData\Local\Temp\vcredist_x64_2015.log
2017/1/10:21:39:44 sevcan SEVCAN Install Microsoft Visual C++ 2015 Redistributable (x64) Succeeded
2017/1/10:21:39:44 sevcan SEVCAN Download Play DIRECTX http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/DIRECTX.t...
2017/1/10:21:39:54 sevcan SEVCAN Download Complete DIRECTX http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/DIRECTX.t...
2017/1/10:21:39:54 sevcan SEVCAN Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\DirectX\DXSETUP.exe" /silent
2017/1/10:21:40:02 sevcan SEVCAN Install DirectX Runtime Succeeded
2017/1/10:21:40:02 sevcan SEVCAN Download Play CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lz...
2017/1/10:21:42:49 sevcan SEVCAN Download Aborted CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lz...
2017/1/10:21:42:49 sevcan SEVCAN Install Autodesk Material Library 2017 Failed Download Failed, Installation aborted, Result=1603
2017/1/10:21:42:49 sevcan SEVCAN Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2017/1/10:21:42:49 sevcan SEVCAN Rollback Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1619
2017/1/10:21:42:49 sevcan SEVCAN Rollback Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1619
2017/1/10:21:42:50 sevcan SEVCAN PageOpen InstallCompleteDialog
2017/1/10:21:48:17 sevcan SEVCAN === Setup ended ===
2017/1/10:22:03:33 sevcan SEVCAN === Setup started on SEVCAN by sevcan ===
2017/1/10:22:03:33 sevcan SEVCAN Path_Length: 162
2017/1/10:22:03:33 sevcan SEVCAN Current Directory C:\Autodesk\AutoCAD_2017_English_Win_32_64bit_Trial_en-us
2017/1/10:22:03:33 sevcan SEVCAN Launch
2017/1/10:22:03:33 sevcan SEVCAN CommandLine /PK 001I1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_English_Win_32_64bit_Trial_en-us_Se..."
2017/1/10:22:03:33 sevcan SEVCAN Current Directory C:\Users\pc\AppData\Local\Temp\_AIC607.tmp
2017/1/10:22:03:35 sevcan SEVCAN === Setup ended ===
2017/1/10:22:03:34 sevcan SEVCAN === Setup started on SEVCAN by sevcan ===
2017/1/10:22:03:34 sevcan SEVCAN Path_Length: 162
2017/1/10:22:03:34 sevcan SEVCAN Current Directory C:\Users\pc\AppData\Local\Temp\_AIC607.tmp
2017/1/10:22:03:34 sevcan SEVCAN Launch
2017/1/10:22:03:34 sevcan SEVCAN Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUPMARK...
2017/1/10:22:03:34 sevcan SEVCAN Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUP_x64...
2017/1/10:22:03:34 sevcan SEVCAN Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\pc\AppData\Local\Temp\_AIC607.tmp\Setup\AcSetup.dll
2017/1/10:22:03:34 sevcan SEVCAN Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/1/10:22:03:35 sevcan SEVCAN PageOpen LaunchDialog
2017/1/10:22:03:56 sevcan SEVCAN PageOpen LicenseDialog
2017/1/10:22:03:56 sevcan SEVCAN PageOpen ProductInfoDialog
2017/1/10:22:03:56 sevcan SEVCAN PageOpen ProductSelectionDialog2
2017/1/10:22:04:17 sevcan SEVCAN PageOpen FullProgressDialog
2017/1/10:22:04:18 sevcan SEVCAN Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARK...
2017/1/10:22:04:18 sevcan SEVCAN Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARK...
2017/1/10:22:04:18 sevcan SEVCAN Download Skipped DOTNET46 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/DOTNET46....
2017/1/10:22:04:18 sevcan SEVCAN Installing .NET Framework Runtime 4.6: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\dotNetFramework\46\dotNetFx46_Full_x86_x64.exe" /q /norestart
2017/1/10:22:04:50 sevcan SEVCAN Install .NET Framework Runtime 4.6 Failed Failure is ignored, Result=1603
2017/1/10:22:04:50 sevcan SEVCAN Download Skipped UCRT http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/UCRT_x86....
2017/1/10:22:04:50 sevcan SEVCAN Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2017/1/10:22:04:50 sevcan SEVCAN Install Universal C Runtime (KB3118401) Succeeded
2017/1/10:22:04:50 sevcan SEVCAN Download Skipped VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2017/1/10:22:04:50 sevcan SEVCAN Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\pc\AppData\Local\Temp\vcredist_x86_2015.log
2017/1/10:22:04:51 sevcan SEVCAN Install Microsoft Visual C++ 2015 Redistributable (x86) Succeeded
2017/1/10:22:04:51 sevcan SEVCAN Download Skipped VCREDIST2015X64 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2017/1/10:22:04:51 sevcan SEVCAN Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\pc\AppData\Local\Temp\vcredist_x64_2015.log
2017/1/10:22:04:52 sevcan SEVCAN Install Microsoft Visual C++ 2015 Redistributable (x64) Succeeded
2017/1/10:22:04:52 sevcan SEVCAN Download Skipped DIRECTX http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/DIRECTX.t...
2017/1/10:22:04:52 sevcan SEVCAN Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\DirectX\DXSETUP.exe" /silent
2017/1/10:22:04:58 sevcan SEVCAN Install DirectX Runtime Succeeded
2017/1/10:22:04:58 sevcan SEVCAN Download Play CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lz...
2017/1/10:22:10:39 sevcan SEVCAN Download Aborted CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lz...
2017/1/10:22:10:39 sevcan SEVCAN Install Autodesk Material Library 2017 Failed Download Failed, Installation aborted, Result=1603
2017/1/10:22:10:39 sevcan SEVCAN Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2017/1/10:22:10:39 sevcan SEVCAN Rollback Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1619
2017/1/10:22:10:39 sevcan SEVCAN Rollback Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1619
Çözüldü! Çözüme gidin.
TuncayBAKKAL01 tarafından çözüldü. Çözüme gidin.
mpeperkamp tarafından çözüldü. Çözüme gidin.
Hi @Anonymous,
Your problem is the 1603 error, which is in error.
The following site will help you:
This is also an option:
1. Access the Autodesk Virtual Agent and follow the download links to your product.
2. Download all of the parts (some applications only have a single part to download) for your product first. Do not continue until all of the parts have fully downloaded.
3. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
4. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
5. Once the extraction is finished, the installation will automatically start.
6. Follow the installation steps for your product
Good luck on your installation.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Merhaba,
Autodesk Öğenci sürümü indirme sayfasında, versiyon ve dil bilgilerini girdikten sonra çıkan INSTALL butonu yanındaki ok içaretine basarak menüyü açın. Açılır menüden BROWSER DOWNLOAD seçerek offline kurulum dosyalarını indirin. 2 adet sfx uzantılı dosya gelecektir. Kurulumu bu dosyalar üzerinden yapmanızı öneririm.
TuncayBAKKAL
AutoCAD Eğitmeni ve Danışmanı
AutoCAD ve Fusion 360 Görsel Eğitim
Fusion 360 Kitabı Çıktı!
http://www.tuncaybakkal.com
Instagram: @tuncay_bakkal
Forumlarımızda çözülen sorularınızı "ÇÖZÜM OLARAK KABUL ET" ("Accept as Solution") seçimiyle işaretlemeyi lütfen unutmayın.
Beğendiğiniz mesajları lütfen "Övgü Puanı" ("Kudos") ile ödüllendirin.
Aradığınızı bulamadınız mı? Topluluğa sorun veya bilgilerinizi paylaşın.
