2016/12/14:17:12:20 ASUS ASUS_PC === Setup started on ASUS_PC by ASUS ===
2016/12/14:17:12:20 ASUS ASUS_PC Path_Length: 162
2016/12/14:17:12:20 ASUS ASUS_PC Current Directory C:\Autodesk\AutoCAD_2017_English_Win_32_64bit_Trial_en-us
2016/12/14:17:12:20 ASUS ASUS_PC Launch
2016/12/14:17:12:20 ASUS ASUS_PC CommandLine /akamai /sid SESSION_ID /skipEULA /trialMode /url "http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_English_Win_32_64bit_Trial_en-us_Setu..."
2016/12/14:17:12:20 ASUS ASUS_PC Current Directory C:\Users\ASUS\AppData\Local\Temp\_AI1D12.tmp
2016/12/14:17:12:29 ASUS ASUS_PC === Setup ended ===
2016/12/14:17:12:22 ASUS ASUS_PC === Setup started on ASUS_PC by ASUS ===
2016/12/14:17:12:22 ASUS ASUS_PC Path_Length: 162
2016/12/14:17:12:22 ASUS ASUS_PC Current Directory C:\Users\ASUS\AppData\Local\Temp\_AI1D12.tmp
2016/12/14:17:12:22 ASUS ASUS_PC Launch
2016/12/14:17:12:27 ASUS ASUS_PC Download Skipped SETUPMARKER http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUPMARKER...
2016/12/14:17:12:27 ASUS ASUS_PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUP_x64.t...
2016/12/14:17:12:27 ASUS ASUS_PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ASUS\AppData\Local\Temp\_AI1D12.tmp\Setup\AcSetup.dll
2016/12/14:17:12:27 ASUS ASUS_PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/12/14:17:12:33 ASUS ASUS_PC PageOpen LaunchDialog
2016/12/14:17:12:46 ASUS ASUS_PC PageOpen LicenseDialog
2016/12/14:17:12:46 ASUS ASUS_PC PageOpen ProductInfoDialog
2016/12/14:17:12:46 ASUS ASUS_PC PageOpen ProductSelectionDialog2
2016/12/14:17:12:58 ASUS ASUS_PC PageOpen FullProgressDialog
2016/12/14:17:12:59 ASUS ASUS_PC Download Play STARTMARKER http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARKER...
2016/12/14:17:12:59 ASUS ASUS_PC Download Complete STARTMARKER http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARKER...
2016/12/14:17:12:59 ASUS ASUS_PC Download Skipped UCRT http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/UCRT_x86.ta...
2016/12/14:17:12:59 ASUS ASUS_PC Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2016/12/14:17:12:59 ASUS ASUS_PC Install Universal C Runtime (KB3118401) Succeeded
2016/12/14:17:13:00 ASUS ASUS_PC Download Skipped VCREDIST2015X86 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST201...
2016/12/14:17:13:00 ASUS ASUS_PC Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\ASUS\AppData\Local\Temp\vcredist_x86_2015.log
2016/12/14:17:13:01 ASUS ASUS_PC Install Microsoft Visual C++ 2015 Redistributable (x86) Succeeded
2016/12/14:17:13:01 ASUS ASUS_PC Download Skipped VCREDIST2015X64 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST201...
2016/12/14:17:13:01 ASUS ASUS_PC Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\ASUS\AppData\Local\Temp\vcredist_x64_2015.log
2016/12/14:17:13:02 ASUS ASUS_PC Install Microsoft Visual C++ 2015 Redistributable (x64) Succeeded
2016/12/14:17:13:02 ASUS ASUS_PC Download Skipped DIRECTX http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/DIRECTX.tar...
2016/12/14:17:13:02 ASUS ASUS_PC Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\DirectX\DXSETUP.exe" /silent
2016/12/14:17:13:10 ASUS ASUS_PC Install DirectX Runtime Succeeded
2016/12/14:17:13:10 ASUS ASUS_PC Download Play CM http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lzma...
2016/12/14:17:35:37 ASUS ASUS_PC Download Aborted CM http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lzma...
2016/12/14:17:35:37 ASUS ASUS_PC Install Autodesk Material Library 2017 Failed Download Failed, Installation aborted, Result=1603
2016/12/14:17:35:38 ASUS ASUS_PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2016/12/14:17:35:38 ASUS ASUS_PC Rollback Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1619
2016/12/14:17:35:38 ASUS ASUS_PC Rollback Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1619
2016/12/14:17:35:39 ASUS ASUS_PC PageOpen InstallCompleteDialog
2016/12/14:17:37:32 ASUS ASUS_PC === Setup ended ===
2016/12/14:18:04:32 ASUS ASUS_PC === Setup started on ASUS_PC by ASUS ===
2016/12/14:18:04:32 ASUS ASUS_PC Path_Length: 162
2016/12/14:18:04:32 ASUS ASUS_PC Current Directory C:\Autodesk\AutoCAD_2017_English_Win_32_64bit_Trial_en-us
2016/12/14:18:04:32 ASUS ASUS_PC Launch
2016/12/14:18:04:32 ASUS ASUS_PC CommandLine /akamai /sid SESSION_ID /skipEULA /trialMode /url "http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_English_Win_32_64bit_Trial_en-us_Setu..."
2016/12/14:18:04:32 ASUS ASUS_PC Current Directory C:\Users\ASUS\AppData\Local\Temp\_AI7FA6.tmp
2016/12/15:08:53:46 ASUS ASUS_PC === Setup ended ===
2016/12/14:18:04:34 ASUS ASUS_PC === Setup started on ASUS_PC by ASUS ===
2016/12/14:18:04:34 ASUS ASUS_PC Path_Length: 162
2016/12/14:18:04:34 ASUS ASUS_PC Current Directory C:\Users\ASUS\AppData\Local\Temp\_AI7FA6.tmp
2016/12/14:18:04:34 ASUS ASUS_PC Launch
2016/12/14:18:04:35 ASUS ASUS_PC Download Play SETUPMARKER http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUPMARKER...
2016/12/14:18:04:35 ASUS ASUS_PC Download Complete SETUPMARKER http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUPMARKER...
2016/12/14:18:04:35 ASUS ASUS_PC Download Play SETUP_CONFIG http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUP_x64.t...
2016/12/14:18:11:01 ASUS ASUS_PC Download Error SETUP_CONFIG <B>Connection has expired.</B>Please Install Now again from the Autodesk website. http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUP_x64.t...
2016/12/14:18:11:01 ASUS ASUS_PC Download Error SETUP_CONFIG Decompressing failed http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUP_x64.t...
2016/12/14:18:11:02 ASUS ASUS_PC Download Aborted SETUP_CONFIG http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUP_x64.t...
2016/12/14:18:11:02 ASUS ASUS_PC Error downloading. Please Install Now again from the Autodesk website. 2016/12/15:08:53:47 ASUS ASUS_PC === Setup ended ===
2016/12/15:09:05:20 ASUS ASUS_PC === Setup started on ASUS_PC by ASUS ===
2016/12/15:09:05:20 ASUS ASUS_PC Path_Length: 162
2016/12/15:09:05:20 ASUS ASUS_PC Current Directory C:\Users\ASUS\AppData\Local\Temp\_AI2AF1.tmp
2016/12/15:09:05:20 ASUS ASUS_PC Launch
2016/12/15:09:05:34 ASUS ASUS_PC === Setup ended ===
2016/12/15:09:05:17 ASUS ASUS_PC === Setup started on ASUS_PC by ASUS ===
2016/12/15:09:05:17 ASUS ASUS_PC Path_Length: 162
2016/12/15:09:05:17 ASUS ASUS_PC Current Directory C:\Autodesk\AutoCAD_2017_English_Win_32_64bit_Trial_en-us
2016/12/15:09:05:17 ASUS ASUS_PC Launch
2016/12/15:09:05:17 ASUS ASUS_PC CommandLine
2016/12/15:09:05:17 ASUS ASUS_PC Current Directory C:\Users\ASUS\AppData\Local\Temp\_AI2AF1.tmp
2016/12/15:09:05:35 ASUS ASUS_PC === Setup ended ===
2016/12/15:09:08:03 ASUS ASUS_PC === Setup started on ASUS_PC by ASUS ===
2016/12/15:09:08:03 ASUS ASUS_PC Path_Length: 162
2016/12/15:09:08:03 ASUS ASUS_PC Current Directory C:\Autodesk\AutoCAD_2017_English_Win_32_64bit_Trial_en-us
2016/12/15:09:08:03 ASUS ASUS_PC Launch
2016/12/15:09:08:03 ASUS ASUS_PC CommandLine /akamai /sid SESSION_ID /skipEULA /trialMode /url "http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_English_Win_32_64bit_Trial_en-us_Setu..."
2016/12/15:09:08:03 ASUS ASUS_PC Current Directory C:\Users\ASUS\AppData\Local\Temp\_AIB44C.tmp
2016/12/15:09:16:09 ASUS ASUS_PC === Setup ended ===
2016/12/15:09:08:06 ASUS ASUS_PC === Setup started on ASUS_PC by ASUS ===
2016/12/15:09:08:06 ASUS ASUS_PC Path_Length: 162
2016/12/15:09:08:06 ASUS ASUS_PC Current Directory C:\Users\ASUS\AppData\Local\Temp\_AIB44C.tmp
2016/12/15:09:08:06 ASUS ASUS_PC Launch
2016/12/15:09:08:08 ASUS ASUS_PC Download Play SETUPMARKER http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUPMARKER...
2016/12/15:09:08:24 ASUS ASUS_PC Download Complete SETUPMARKER http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUPMARKER...
2016/12/15:09:08:25 ASUS ASUS_PC Download Play SETUP_CONFIG http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUP_x64.t...
2016/12/15:09:16:08 ASUS ASUS_PC Download Complete SETUP_CONFIG http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUP_x64.t...
2016/12/15:09:16:08 ASUS ASUS_PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ASUS\AppData\Local\Temp\_AIB44C.tmp\Setup\AcSetup.dll
2016/12/15:09:16:08 ASUS ASUS_PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/12/15:09:16:09 ASUS ASUS_PC PageOpen LaunchDialog
2016/12/15:09:19:15 ASUS ASUS_PC PageOpen LicenseDialog
2016/12/15:09:19:15 ASUS ASUS_PC PageOpen ProductInfoDialog
2016/12/15:09:19:15 ASUS ASUS_PC PageOpen ProductSelectionDialog2
2016/12/15:09:19:56 ASUS ASUS_PC PageOpen FullProgressDialog
2016/12/15:09:19:56 ASUS ASUS_PC Download Play STARTMARKER http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARKER...
2016/12/15:09:19:57 ASUS ASUS_PC Download Complete STARTMARKER http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARKER...
2016/12/15:09:19:57 ASUS ASUS_PC Download Play VCREDIST2008SP1X86 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST200...
2016/12/15:09:20:08 ASUS ASUS_PC Download Complete VCREDIST2008SP1X86 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST200...
2016/12/15:09:20:08 ASUS ASUS_PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2016/12/15:09:20:37 ASUS ASUS_PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2016/12/15:09:20:37 ASUS ASUS_PC Download Play VCREDIST2008SP1X64 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST200...
2016/12/15:09:20:53 ASUS ASUS_PC Download Complete VCREDIST2008SP1X64 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST200...
2016/12/15:09:20:53 ASUS ASUS_PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2016/12/15:09:21:15 ASUS ASUS_PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2016/12/15:09:21:15 ASUS ASUS_PC Download Play VCREDIST2010SP1X86 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST201...
2016/12/15:09:21:30 ASUS ASUS_PC Download Complete VCREDIST2010SP1X86 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST201...
2016/12/15:09:21:30 ASUS ASUS_PC Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe" /q /norestart /l C:\Users\ASUS\AppData\Local\Temp\vcredist_x86_2010.log
2016/12/15:09:21:37 ASUS ASUS_PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2016/12/15:09:21:37 ASUS ASUS_PC Download Play VCREDIST2010SP1X64 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST201...
2016/12/15:09:21:52 ASUS ASUS_PC Download Complete VCREDIST2010SP1X64 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST201...
2016/12/15:09:21:52 ASUS ASUS_PC Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe" /q /norestart /l C:\Users\ASUS\AppData\Local\Temp\vcredist_x64_2010.log
2016/12/15:09:22:01 ASUS ASUS_PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2016/12/15:09:22:01 ASUS ASUS_PC Download Play VCREDIST2012X86UPD4 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST201...
2016/12/15:09:22:18 ASUS ASUS_PC Download Complete VCREDIST2012X86UPD4 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST201...
2016/12/15:09:22:18 ASUS ASUS_PC Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\ASUS\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2016/12/15:09:22:26 ASUS ASUS_PC Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2016/12/15:09:22:26 ASUS ASUS_PC Download Play VCREDIST2012X64UPD4 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST201...
2016/12/15:09:22:48 ASUS ASUS_PC Download Complete VCREDIST2012X64UPD4 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST201...
2016/12/15:09:22:48 ASUS ASUS_PC Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\ASUS\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2016/12/15:09:22:54 ASUS ASUS_PC Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2016/12/15:09:22:54 ASUS ASUS_PC Download Play UCRT http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/UCRT_x86.ta...
2016/12/15:09:23:09 ASUS ASUS_PC Download Complete UCRT http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/UCRT_x86.ta...
2016/12/15:09:23:09 ASUS ASUS_PC Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2016/12/15:09:23:10 ASUS ASUS_PC Install Universal C Runtime (KB3118401) Succeeded
2016/12/15:09:23:10 ASUS ASUS_PC Download Play VCREDIST2015X86 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST201...
2016/12/15:09:23:45 ASUS ASUS_PC Download Complete VCREDIST2015X86 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST201...
2016/12/15:09:23:45 ASUS ASUS_PC Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\ASUS\AppData\Local\Temp\vcredist_x86_2015.log
2016/12/15:09:23:48 ASUS ASUS_PC Install Microsoft Visual C++ 2015 Redistributable (x86) Succeeded
2016/12/15:09:23:49 ASUS ASUS_PC Download Play VCREDIST2015X64 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST201...
2016/12/15:09:24:26 ASUS ASUS_PC Download Complete VCREDIST2015X64 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST201...
2016/12/15:09:24:26 ASUS ASUS_PC Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\ASUS\AppData\Local\Temp\vcredist_x64_2015.log
2016/12/15:09:24:38 ASUS ASUS_PC Install Microsoft Visual C++ 2015 Redistributable (x64) Succeeded
2016/12/15:09:24:39 ASUS ASUS_PC Download Play DIRECTX http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/DIRECTX.tar...
2016/12/15:09:25:19 ASUS ASUS_PC Download Complete DIRECTX http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/DIRECTX.tar...
2016/12/15:09:25:19 ASUS ASUS_PC Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\DirectX\DXSETUP.exe" /silent
2016/12/15:09:26:21 ASUS ASUS_PC Install DirectX Runtime Succeeded
2016/12/15:09:26:21 ASUS ASUS_PC Download Play CM http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lzma...
2016/12/15:09:40:19 ASUS ASUS_PC Download Aborted CM http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lzma...
2016/12/15:09:40:19 ASUS ASUS_PC Install Autodesk Material Library 2017 Failed Download Failed, Installation aborted, Result=1603
2016/12/15:09:40:20 ASUS ASUS_PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2016/12/15:09:40:20 ASUS ASUS_PC Rollback Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1619
2016/12/15:09:40:20 ASUS ASUS_PC Rollback Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1619
2016/12/15:09:40:20 ASUS ASUS_PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Failure is ignored, Result=1619
2016/12/15:09:40:20 ASUS ASUS_PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Failure is ignored, Result=1619
2016/12/15:09:40:20 ASUS ASUS_PC Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2016/12/15:09:40:20 ASUS ASUS_PC Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
Çözüldü! Çözüme gidin.
Gokhan_Kaya tarafından çözüldü. Çözüme gidin.
Merhabalar
Aşağıdaki linklerden size uygun olan microsoft mimarisine göre Autocad 2017 yükleme medyasını indirip kurabilirsiniz
32 bit işletim sistemi için
http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/DLM/AutoCAD_2017_English_Win_32bit_dlm.sfx.exe?...
64Bit işletim sistemi için
Part 1
http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/DLM/AutoCAD_2017_English_Win_64bit_dlm_001_002....
Part 2
http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/DLM/AutoCAD_2017_English_Win_64bit_dlm_002_002....
Gökhan Kaya
Tehcnical Manager
Autodesk Inventor Certified Professional 2015
LinkedIn
MSI WS 60 i7 Quadro M2000M
2017/3/28:14:29:16 Gül DESKTOP-B7S3NUH === Setup started on DESKTOP-B7S3NUH by Gül ===
2017/3/28:14:29:16 Gül DESKTOP-B7S3NUH Path_Length: 158
2017/3/28:14:29:16 Gül DESKTOP-B7S3NUH Current Directory C:\Autodesk\AutoCAD_2018_English_Win_32_64bit_Trial_en-us
2017/3/28:14:29:16 Gül DESKTOP-B7S3NUH Launch
2017/3/28:14:29:16 Gül DESKTOP-B7S3NUH CommandLine /PK 001J1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/AutoCAD_201..."
2017/3/28:14:29:16 Gül DESKTOP-B7S3NUH Current Directory C:\Users\GLDF8B~1\AppData\Local\Temp\_AI6B0C.tmp
2017/3/28:14:37:11 Gül DESKTOP-B7S3NUH === Setup ended ===
2017/3/28:14:29:17 Gül DESKTOP-B7S3NUH === Setup started on DESKTOP-B7S3NUH by Gül ===
2017/3/28:14:29:17 Gül DESKTOP-B7S3NUH Path_Length: 158
2017/3/28:14:29:17 Gül DESKTOP-B7S3NUH Current Directory C:\Users\GLDF8B~1\AppData\Local\Temp\_AI6B0C.tmp
2017/3/28:14:29:17 Gül DESKTOP-B7S3NUH Launch
2017/3/28:14:29:19 Gül DESKTOP-B7S3NUH Download Play SETUPMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/28:14:29:20 Gül DESKTOP-B7S3NUH Download Complete SETUPMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/28:14:29:21 Gül DESKTOP-B7S3NUH Download Play SETUP_CONFIG http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/28:14:37:10 Gül DESKTOP-B7S3NUH Download Complete SETUP_CONFIG http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/28:14:37:10 Gül DESKTOP-B7S3NUH Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\GLDF8B~1\AppData\Local\Temp\_AI6B0C.tmp\Setup\AcSetup.dll
2017/3/28:14:37:10 Gül DESKTOP-B7S3NUH Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/3/28:14:37:12 Gül DESKTOP-B7S3NUH PageOpen LaunchDialog
2017/3/28:14:37:24 Gül DESKTOP-B7S3NUH PageOpen LicenseDialog
2017/3/28:14:37:24 Gül DESKTOP-B7S3NUH PageOpen ProductInfoDialog
2017/3/28:14:37:24 Gül DESKTOP-B7S3NUH PageOpen ProductSelectionDialog2
2017/3/28:14:38:13 Gül DESKTOP-B7S3NUH PageOpen FullProgressDialog
2017/3/28:14:38:13 Gül DESKTOP-B7S3NUH Download Play STARTMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/28:14:38:13 Gül DESKTOP-B7S3NUH Download Complete STARTMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/28:14:38:14 Gül DESKTOP-B7S3NUH Download Play UCRT http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/28:14:38:25 Gül DESKTOP-B7S3NUH Download Complete UCRT http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/28:14:38:25 Gül DESKTOP-B7S3NUH Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2018\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2017/3/28:14:38:26 Gül DESKTOP-B7S3NUH Universal C Runtime (KB3118401) return code: 0
2017/3/28:14:38:26 Gül DESKTOP-B7S3NUH Install Universal C Runtime (KB3118401) Succeeded
2017/3/28:14:38:26 Gül DESKTOP-B7S3NUH Download Play VCREDIST2015X86 http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/28:14:38:53 Gül DESKTOP-B7S3NUH Download Complete VCREDIST2015X86 http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/28:14:38:53 Gül DESKTOP-B7S3NUH Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2018\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\GLDF8B~1\AppData\Local\Temp\vcredist_x86_2015.log
2017/3/28:14:39:36 Gül DESKTOP-B7S3NUH Microsoft Visual C++ 2015 Redistributable (x86) return code: 0
2017/3/28:14:39:36 Gül DESKTOP-B7S3NUH Install Microsoft Visual C++ 2015 Redistributable (x86) Succeeded
2017/3/28:14:39:37 Gül DESKTOP-B7S3NUH Download Play VCREDIST2015X64 http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/28:14:40:04 Gül DESKTOP-B7S3NUH Download Complete VCREDIST2015X64 http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/28:14:40:04 Gül DESKTOP-B7S3NUH Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2018\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\GLDF8B~1\AppData\Local\Temp\vcredist_x64_2015.log
2017/3/28:14:40:16 Gül DESKTOP-B7S3NUH Microsoft Visual C++ 2015 Redistributable (x64) return code: 3010
2017/3/28:14:40:16 Gül DESKTOP-B7S3NUH Install Microsoft Visual C++ 2015 Redistributable (x64) Succeeded
2017/3/28:14:40:16 Gül DESKTOP-B7S3NUH Download Play DIRECTX http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/28:14:40:46 Gül DESKTOP-B7S3NUH Download Complete DIRECTX http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/28:14:40:46 Gül DESKTOP-B7S3NUH Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2018\3rdParty\DirectX\DXSETUP.exe" /silent
2017/3/28:14:41:03 Gül DESKTOP-B7S3NUH DirectX Runtime return code: 0
2017/3/28:14:41:03 Gül DESKTOP-B7S3NUH Install DirectX Runtime Succeeded
2017/3/28:14:41:03 Gül DESKTOP-B7S3NUH Download Play CM http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/28:14:51:12 Gül DESKTOP-B7S3NUH Download Complete CM http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/28:14:51:12 Gül DESKTOP-B7S3NUH Installing Autodesk Material Library 2018: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2018" SETUP_PACKAGECODE={DD42F784-12DC-49EE-8045-600335BE940B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={D7AC923A-BC24-471F-ABC1-E578C6B5D699} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/28:14:51:39 Gül DESKTOP-B7S3NUH Install Autodesk Material Library 2018 Succeeded
2017/3/28:14:51:41 Gül DESKTOP-B7S3NUH Download Play CMILB http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/28:14:53:25 Gül DESKTOP-B7S3NUH Download Error CMILB <B>Connection has expired.</B>Please Install Now again from the Autodesk website. http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/28:14:53:25 Gül DESKTOP-B7S3NUH Download Aborted CMILB http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/28:14:53:25 Gül DESKTOP-B7S3NUH Install Autodesk Material Library 2018 - Base Image Library Failed Download Failed, Installation aborted, Result=1603
2017/3/28:14:53:43 Gül DESKTOP-B7S3NUH Rollback Autodesk Material Library 2018 Succeeded
2017/3/28:14:53:43 Gül DESKTOP-B7S3NUH Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2017/3/28:14:53:43 Gül DESKTOP-B7S3NUH Rollback Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1619
2017/3/28:14:53:43 Gül DESKTOP-B7S3NUH Rollback Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1619
2017/3/28:14:53:44 Gül DESKTOP-B7S3NUH PageOpen InstallCompleteDialog
2017/3/28:15:02:49 Gül DESKTOP-B7S3NUH === Setup ended ===
2017/3/28:15:44:47 Gül DESKTOP-B7S3NUH === Setup started on DESKTOP-B7S3NUH by Gül ===
2017/3/28:15:44:47 Gül DESKTOP-B7S3NUH Path_Length: 158
2017/3/28:15:44:47 Gül DESKTOP-B7S3NUH Current Directory C:\Autodesk\AutoCAD_2018_English_Win_32_64bit_Trial_en-us
2017/3/28:15:44:47 Gül DESKTOP-B7S3NUH Launch
2017/3/28:15:44:47 Gül DESKTOP-B7S3NUH CommandLine /PK 001J1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/AutoCAD_201..."
2017/3/28:15:44:47 Gül DESKTOP-B7S3NUH Current Directory C:\Users\GLDF8B~1\AppData\Local\Temp\_AIDDD6.tmp
2017/3/28:15:44:55 Gül DESKTOP-B7S3NUH === Setup ended ===
2017/3/28:15:44:48 Gül DESKTOP-B7S3NUH === Setup started on DESKTOP-B7S3NUH by Gül ===
2017/3/28:15:44:48 Gül DESKTOP-B7S3NUH Path_Length: 158
2017/3/28:15:44:48 Gül DESKTOP-B7S3NUH Current Directory C:\Users\GLDF8B~1\AppData\Local\Temp\_AIDDD6.tmp
2017/3/28:15:44:48 Gül DESKTOP-B7S3NUH Launch
2017/3/28:15:44:50 Gül DESKTOP-B7S3NUH Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/28:15:44:50 Gül DESKTOP-B7S3NUH Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/28:15:44:51 Gül DESKTOP-B7S3NUH Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\GLDF8B~1\AppData\Local\Temp\_AIDDD6.tmp\Setup\AcSetup.dll
2017/3/28:15:44:51 Gül DESKTOP-B7S3NUH Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/3/28:15:44:52 Gül DESKTOP-B7S3NUH PageOpen LaunchDialog
2017/3/28:15:45:08 Gül DESKTOP-B7S3NUH PageOpen LicenseDialog
2017/3/28:15:45:08 Gül DESKTOP-B7S3NUH PageOpen ProductInfoDialog
2017/3/28:15:45:08 Gül DESKTOP-B7S3NUH PageOpen ProductSelectionDialog2
2017/3/28:15:45:15 Gül DESKTOP-B7S3NUH PageOpen FullProgressDialog
2017/3/28:15:45:16 Gül DESKTOP-B7S3NUH Download Play STARTMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/28:15:45:17 Gül DESKTOP-B7S3NUH Download Complete STARTMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/28:15:45:17 Gül DESKTOP-B7S3NUH Download Play VCREDIST2010SP1X86 http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/28:15:45:32 Gül DESKTOP-B7S3NUH Download Complete VCREDIST2010SP1X86 http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/28:15:45:32 Gül DESKTOP-B7S3NUH Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2018\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe" /q /norestart /l C:\Users\GLDF8B~1\AppData\Local\Temp\vcredist_x86_2010.log
2017/3/28:15:45:42 Gül DESKTOP-B7S3NUH Microsoft Visual C++ 2010 SP1 Redistributable (x86) return code: 0
2017/3/28:15:45:42 Gül DESKTOP-B7S3NUH Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2017/3/28:15:45:43 Gül DESKTOP-B7S3NUH Download Play VCREDIST2010SP1X64 http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/28:15:46:17 Gül DESKTOP-B7S3NUH Download Complete VCREDIST2010SP1X64 http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/28:15:46:17 Gül DESKTOP-B7S3NUH Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2018\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe" /q /norestart /l C:\Users\GLDF8B~1\AppData\Local\Temp\vcredist_x64_2010.log
2017/3/28:15:46:27 Gül DESKTOP-B7S3NUH Microsoft Visual C++ 2010 SP1 Redistributable (x64) return code: 0
2017/3/28:15:46:27 Gül DESKTOP-B7S3NUH Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2017/3/28:15:46:27 Gül DESKTOP-B7S3NUH Download Skipped UCRT http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/28:15:46:27 Gül DESKTOP-B7S3NUH Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2018\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2017/3/28:15:46:27 Gül DESKTOP-B7S3NUH Universal C Runtime (KB3118401) return code: 0
2017/3/28:15:46:27 Gül DESKTOP-B7S3NUH Install Universal C Runtime (KB3118401) Succeeded
2017/3/28:15:46:28 Gül DESKTOP-B7S3NUH Download Skipped VCREDIST2015X86 http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/28:15:46:28 Gül DESKTOP-B7S3NUH Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2018\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\GLDF8B~1\AppData\Local\Temp\vcredist_x86_2015.log
2017/3/28:15:46:32 Gül DESKTOP-B7S3NUH Microsoft Visual C++ 2015 Redistributable (x86) return code: 0
2017/3/28:15:46:32 Gül DESKTOP-B7S3NUH Install Microsoft Visual C++ 2015 Redistributable (x86) Succeeded
2017/3/28:15:46:32 Gül DESKTOP-B7S3NUH Download Skipped VCREDIST2015X64 http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/28:15:46:32 Gül DESKTOP-B7S3NUH Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2018\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\GLDF8B~1\AppData\Local\Temp\vcredist_x64_2015.log
2017/3/28:15:46:40 Gül DESKTOP-B7S3NUH Microsoft Visual C++ 2015 Redistributable (x64) return code: 0
2017/3/28:15:46:40 Gül DESKTOP-B7S3NUH Install Microsoft Visual C++ 2015 Redistributable (x64) Succeeded
2017/3/28:15:46:41 Gül DESKTOP-B7S3NUH Download Skipped DIRECTX http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/28:15:46:41 Gül DESKTOP-B7S3NUH Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2018\3rdParty\DirectX\DXSETUP.exe" /silent
2017/3/28:15:46:55 Gül DESKTOP-B7S3NUH DirectX Runtime return code: 0
2017/3/28:15:46:55 Gül DESKTOP-B7S3NUH Install DirectX Runtime Succeeded
2017/3/28:15:46:55 Gül DESKTOP-B7S3NUH Download Skipped CM http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/28:15:46:55 Gül DESKTOP-B7S3NUH Installing Autodesk Material Library 2018: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2018" SETUP_PACKAGECODE={DD42F784-12DC-49EE-8045-600335BE940B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={D7AC923A-BC24-471F-ABC1-E578C6B5D699} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/28:15:47:20 Gül DESKTOP-B7S3NUH Install Autodesk Material Library 2018 Succeeded
2017/3/28:15:47:20 Gül DESKTOP-B7S3NUH Download Play CMILB http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/28:15:51:04 Gül DESKTOP-B7S3NUH Download Complete CMILB http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/28:15:51:04 Gül DESKTOP-B7S3NUH Installing Autodesk Material Library 2018 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2018" SETUP_PACKAGECODE={DD42F784-12DC-49EE-8045-600335BE940B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={D7AC923A-BC24-471F-ABC1-E578C6B5D699} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/28:15:51:51 Gül DESKTOP-B7S3NUH Install Autodesk Material Library 2018 - Base Image Library Succeeded
2017/3/28:15:51:52 Gül DESKTOP-B7S3NUH Download Play CMAIL http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/28:15:56:45 Gül DESKTOP-B7S3NUH Download Complete CMAIL http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/28:15:56:45 Gül DESKTOP-B7S3NUH Installing Autodesk® Material Library 2018 - Advanced Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2018" SETUP_PACKAGECODE={DD42F784-12DC-49EE-8045-600335BE940B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{7847611E-92E9-4917-B395-71C91D523104},;;;;" PACKAGEUPI={D7AC923A-BC24-471F-ABC1-E578C6B5D699} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/28:15:56:56 Gül DESKTOP-B7S3NUH Install Autodesk® Material Library 2018 - Advanced Image Library Succeeded
2017/3/28:15:56:57 Gül DESKTOP-B7S3NUH Download Play ACAD http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/28:16:00:10 Gül DESKTOP-B7S3NUH Download Error ACAD <B>Connection has expired.</B>Please Install Now again from the Autodesk website. http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/28:16:00:10 Gül DESKTOP-B7S3NUH Download Error ACAD Unknown error! http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/28:16:00:10 Gül DESKTOP-B7S3NUH Download Aborted ACAD http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/28:16:00:10 Gül DESKTOP-B7S3NUH Install Autodesk® AutoCAD® 2018 Core Failed Download Failed, Installation aborted, Result=1603
2017/3/28:16:00:12 Gül DESKTOP-B7S3NUH Rollback Autodesk® Material Library 2018 - Advanced Image Library Succeeded
2017/3/28:16:00:14 Gül DESKTOP-B7S3NUH Rollback Autodesk Material Library 2018 - Base Image Library Succeeded
2017/3/28:16:00:33 Gül DESKTOP-B7S3NUH Rollback Autodesk Material Library 2018 Succeeded
2017/3/28:16:00:33 Gül DESKTOP-B7S3NUH Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2017/3/28:16:00:33 Gül DESKTOP-B7S3NUH Rollback Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1619
2017/3/28:16:00:34 Gül DESKTOP-B7S3NUH Rollback Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1619
2017/3/28:16:00:34 Gül DESKTOP-B7S3NUH Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2017/3/28:16:00:34 Gül DESKTOP-B7S3NUH Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2017/3/28:16:00:35 Gül DESKTOP-B7S3NUH PageOpen InstallCompleteDialog
2017/3/28:16:04:10 Gül DESKTOP-B7S3NUH === Setup ended ===
2017/3/30:18:13:43 Gül DESKTOP-B7S3NUH === Setup started on DESKTOP-B7S3NUH by Gül ===
2017/3/30:18:13:43 Gül DESKTOP-B7S3NUH Path_Length: 158
2017/3/30:18:13:43 Gül DESKTOP-B7S3NUH Current Directory C:\Autodesk\AutoCAD_2018_English_Win_32_64bit_Trial_en-us
2017/3/30:18:13:43 Gül DESKTOP-B7S3NUH Launch
2017/3/30:18:13:43 Gül DESKTOP-B7S3NUH CommandLine /PK 001J1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/AutoCAD_201..."
2017/3/30:18:13:43 Gül DESKTOP-B7S3NUH Current Directory C:\Users\GLDF8B~1\AppData\Local\Temp\_AI9FD5.tmp
2017/3/30:18:13:48 Gül DESKTOP-B7S3NUH === Setup ended ===
2017/3/30:18:13:44 Gül DESKTOP-B7S3NUH === Setup started on DESKTOP-B7S3NUH by Gül ===
2017/3/30:18:13:44 Gül DESKTOP-B7S3NUH Path_Length: 158
2017/3/30:18:13:44 Gül DESKTOP-B7S3NUH Current Directory C:\Users\GLDF8B~1\AppData\Local\Temp\_AI9FD5.tmp
2017/3/30:18:13:44 Gül DESKTOP-B7S3NUH Launch
2017/3/30:18:13:46 Gül DESKTOP-B7S3NUH Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:18:13:46 Gül DESKTOP-B7S3NUH Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:18:13:47 Gül DESKTOP-B7S3NUH Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\GLDF8B~1\AppData\Local\Temp\_AI9FD5.tmp\Setup\AcSetup.dll
2017/3/30:18:13:47 Gül DESKTOP-B7S3NUH Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/3/30:18:13:48 Gül DESKTOP-B7S3NUH PageOpen LaunchDialog
2017/3/30:18:13:59 Gül DESKTOP-B7S3NUH PageOpen LicenseDialog
2017/3/30:18:13:59 Gül DESKTOP-B7S3NUH PageOpen ProductInfoDialog
2017/3/30:18:13:59 Gül DESKTOP-B7S3NUH PageOpen ProductSelectionDialog2
2017/3/30:18:14:11 Gül DESKTOP-B7S3NUH PageOpen FullProgressDialog
2017/3/30:18:14:13 Gül DESKTOP-B7S3NUH Download Play STARTMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:18:14:14 Gül DESKTOP-B7S3NUH Download Complete STARTMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:18:14:14 Gül DESKTOP-B7S3NUH Download Skipped VCREDIST2010SP1X86 http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:18:14:14 Gül DESKTOP-B7S3NUH Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2018\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe" /q /norestart /l C:\Users\GLDF8B~1\AppData\Local\Temp\vcredist_x86_2010.log
2017/3/30:18:14:21 Gül DESKTOP-B7S3NUH Microsoft Visual C++ 2010 SP1 Redistributable (x86) return code: 0
2017/3/30:18:14:21 Gül DESKTOP-B7S3NUH Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2017/3/30:18:14:21 Gül DESKTOP-B7S3NUH Download Skipped VCREDIST2010SP1X64 http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:18:14:21 Gül DESKTOP-B7S3NUH Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2018\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe" /q /norestart /l C:\Users\GLDF8B~1\AppData\Local\Temp\vcredist_x64_2010.log
2017/3/30:18:14:31 Gül DESKTOP-B7S3NUH Microsoft Visual C++ 2010 SP1 Redistributable (x64) return code: 0
2017/3/30:18:14:31 Gül DESKTOP-B7S3NUH Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2017/3/30:18:14:31 Gül DESKTOP-B7S3NUH Download Skipped DIRECTX http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:18:14:31 Gül DESKTOP-B7S3NUH Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2018\3rdParty\DirectX\DXSETUP.exe" /silent
2017/3/30:18:14:55 Gül DESKTOP-B7S3NUH DirectX Runtime return code: 0
2017/3/30:18:14:55 Gül DESKTOP-B7S3NUH Install DirectX Runtime Succeeded
2017/3/30:18:14:55 Gül DESKTOP-B7S3NUH Download Skipped CM http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:18:14:55 Gül DESKTOP-B7S3NUH Installing Autodesk Material Library 2018: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2018" SETUP_PACKAGECODE={DD42F784-12DC-49EE-8045-600335BE940B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={D7AC923A-BC24-471F-ABC1-E578C6B5D699} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/30:18:15:23 Gül DESKTOP-B7S3NUH Install Autodesk Material Library 2018 Succeeded
2017/3/30:18:15:23 Gül DESKTOP-B7S3NUH Download Skipped CMILB http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:18:15:24 Gül DESKTOP-B7S3NUH Installing Autodesk Material Library 2018 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2018" SETUP_PACKAGECODE={DD42F784-12DC-49EE-8045-600335BE940B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={D7AC923A-BC24-471F-ABC1-E578C6B5D699} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/30:18:15:41 Gül DESKTOP-B7S3NUH Install Autodesk Material Library 2018 - Base Image Library Succeeded
2017/3/30:18:15:42 Gül DESKTOP-B7S3NUH Download Skipped CMAIL http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:18:15:42 Gül DESKTOP-B7S3NUH Installing Autodesk® Material Library 2018 - Advanced Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2018" SETUP_PACKAGECODE={DD42F784-12DC-49EE-8045-600335BE940B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{7847611E-92E9-4917-B395-71C91D523104},;;;;" PACKAGEUPI={D7AC923A-BC24-471F-ABC1-E578C6B5D699} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/30:18:15:50 Gül DESKTOP-B7S3NUH Install Autodesk® Material Library 2018 - Advanced Image Library Succeeded
2017/3/30:18:15:51 Gül DESKTOP-B7S3NUH Download Play ACAD http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:18:22:08 Gül DESKTOP-B7S3NUH Download Error ACAD <B>Connection has expired.</B>Please Install Now again from the Autodesk website. http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:18:22:08 Gül DESKTOP-B7S3NUH Download Error ACAD Unknown error! http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:18:22:08 Gül DESKTOP-B7S3NUH Download Aborted ACAD http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:18:22:08 Gül DESKTOP-B7S3NUH Install Autodesk® AutoCAD® 2018 Core Failed Download Failed, Installation aborted, Result=1603
2017/3/30:18:22:11 Gül DESKTOP-B7S3NUH Rollback Autodesk® Material Library 2018 - Advanced Image Library Succeeded
2017/3/30:18:22:22 Gül DESKTOP-B7S3NUH Rollback Autodesk Material Library 2018 - Base Image Library Succeeded
2017/3/30:18:22:39 Gül DESKTOP-B7S3NUH Rollback Autodesk Material Library 2018 Succeeded
2017/3/30:18:22:39 Gül DESKTOP-B7S3NUH Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2017/3/30:18:22:39 Gül DESKTOP-B7S3NUH Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2017/3/30:18:22:39 Gül DESKTOP-B7S3NUH Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2017/3/30:18:22:42 Gül DESKTOP-B7S3NUH PageOpen InstallCompleteDialog
2017/3/30:18:25:16 Gül DESKTOP-B7S3NUH [Error: 1056] Bir hizmet kopyası halen çalışıyor.
2017/3/30:18:25:16 Gül DESKTOP-B7S3NUH === Setup ended ===
2017/3/30:18:29:30 Gül DESKTOP-B7S3NUH === Setup started on DESKTOP-B7S3NUH by Gül ===
2017/3/30:18:29:30 Gül DESKTOP-B7S3NUH Path_Length: 158
2017/3/30:18:29:30 Gül DESKTOP-B7S3NUH Current Directory C:\Autodesk\AutoCAD_2018_English_Win_32_64bit_Trial_en-us
2017/3/30:18:29:30 Gül DESKTOP-B7S3NUH Launch
2017/3/30:18:29:30 Gül DESKTOP-B7S3NUH CommandLine /PK 001J1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/AutoCAD_201..."
2017/3/30:18:29:30 Gül DESKTOP-B7S3NUH Current Directory C:\Users\GLDF8B~1\AppData\Local\Temp\_AI135C.tmp
2017/3/30:18:29:33 Gül DESKTOP-B7S3NUH === Setup ended ===
2017/3/30:18:29:31 Gül DESKTOP-B7S3NUH === Setup started on DESKTOP-B7S3NUH by Gül ===
2017/3/30:18:29:31 Gül DESKTOP-B7S3NUH Path_Length: 158
2017/3/30:18:29:31 Gül DESKTOP-B7S3NUH Current Directory C:\Users\GLDF8B~1\AppData\Local\Temp\_AI135C.tmp
2017/3/30:18:29:31 Gül DESKTOP-B7S3NUH Launch
2017/3/30:18:29:32 Gül DESKTOP-B7S3NUH Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:18:29:33 Gül DESKTOP-B7S3NUH Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:18:29:33 Gül DESKTOP-B7S3NUH Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\GLDF8B~1\AppData\Local\Temp\_AI135C.tmp\Setup\AcSetup.dll
2017/3/30:18:29:33 Gül DESKTOP-B7S3NUH Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/3/30:18:29:34 Gül DESKTOP-B7S3NUH PageOpen LaunchDialog
2017/3/30:18:29:36 Gül DESKTOP-B7S3NUH PageOpen LicenseDialog
2017/3/30:18:29:36 Gül DESKTOP-B7S3NUH PageOpen ProductSelectionDialog2
2017/3/30:18:29:40 Gül DESKTOP-B7S3NUH PageOpen FullProgressDialog
2017/3/30:18:29:40 Gül DESKTOP-B7S3NUH Installing Network License Manager: ALLUSERS=1 INSTALLDIR="C:\Program Files\Autodesk\Autodesk Network License Manager\" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2018" SETUP_PACKAGECODE={DD42F784-12DC-49EE-8045-600335BE940B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={D7AC923A-BC24-471F-ABC1-E578C6B5D699} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/30:18:29:41 Gül DESKTOP-B7S3NUH Install Network License Manager Succeeded
2017/3/30:18:29:42 Gül DESKTOP-B7S3NUH Download Play STARTMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:18:29:43 Gül DESKTOP-B7S3NUH Download Complete STARTMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:18:29:44 Gül DESKTOP-B7S3NUH Download Play CADM http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:18:29:58 Gül DESKTOP-B7S3NUH Download Complete CADM http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:18:29:58 Gül DESKTOP-B7S3NUH Installing Autodesk CAD Manager Tools: INSTALLDIR="C:\Program Files\Autodesk\Autodesk CAD Manager Tools\" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2018" SETUP_PACKAGECODE={DD42F784-12DC-49EE-8045-600335BE940B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="SSE2 Support Check,Microsoft Visual C++ 2012 Redistributable (x86) Update 4,Microsoft Visual C++ 2012 Redistributable (x64) Update 4,Microsoft Visual C++ 2015 Redistributable (x86),Microsoft Visual C++ 2015 Redistributable (x64),;;;;" PACKAGEUPI={D7AC923A-BC24-471F-ABC1-E578C6B5D699} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2018" INSTALLDIR="C:\Program Files\Autodesk\CAD Manager Tools\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/30:18:30:00 Gül DESKTOP-B7S3NUH Install Autodesk CAD Manager Tools Succeeded
2017/3/30:18:30:00 Gül DESKTOP-B7S3NUH Download Play SUCCESSMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:18:30:00 Gül DESKTOP-B7S3NUH Download Complete SUCCESSMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:18:30:00 Gül DESKTOP-B7S3NUH PageOpen InstallCompleteDialog
2017/3/30:18:30:04 Gül DESKTOP-B7S3NUH === Setup ended ===
2017/3/30:18:32:09 Gül DESKTOP-B7S3NUH === Setup started on DESKTOP-B7S3NUH by Gül ===
2017/3/30:18:32:09 Gül DESKTOP-B7S3NUH Path_Length: 158
2017/3/30:18:32:09 Gül DESKTOP-B7S3NUH Current Directory C:\Autodesk\AutoCAD_2018_English_Win_32_64bit_Trial_en-us
2017/3/30:18:32:09 Gül DESKTOP-B7S3NUH Launch
2017/3/30:18:32:09 Gül DESKTOP-B7S3NUH CommandLine /PK 001J1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/AutoCAD_201..."
2017/3/30:18:32:09 Gül DESKTOP-B7S3NUH Current Directory C:\Users\GLDF8B~1\AppData\Local\Temp\_AI7E80.tmp
2017/3/30:18:32:12 Gül DESKTOP-B7S3NUH === Setup ended ===
2017/3/30:18:32:10 Gül DESKTOP-B7S3NUH === Setup started on DESKTOP-B7S3NUH by Gül ===
2017/3/30:18:32:10 Gül DESKTOP-B7S3NUH Path_Length: 158
2017/3/30:18:32:10 Gül DESKTOP-B7S3NUH Current Directory C:\Users\GLDF8B~1\AppData\Local\Temp\_AI7E80.tmp
2017/3/30:18:32:10 Gül DESKTOP-B7S3NUH Launch
2017/3/30:18:32:11 Gül DESKTOP-B7S3NUH Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:18:32:11 Gül DESKTOP-B7S3NUH Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:18:32:11 Gül DESKTOP-B7S3NUH Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\GLDF8B~1\AppData\Local\Temp\_AI7E80.tmp\Setup\AcSetup.dll
2017/3/30:18:32:11 Gül DESKTOP-B7S3NUH Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/3/30:18:32:11 Gül DESKTOP-B7S3NUH PageOpen LaunchDialog
2017/3/30:18:32:21 Gül DESKTOP-B7S3NUH PageOpen LicenseDialog
2017/3/30:18:32:21 Gül DESKTOP-B7S3NUH PageOpen ProductInfoDialog
2017/3/30:18:32:21 Gül DESKTOP-B7S3NUH PageOpen ProductSelectionDialog2
2017/3/30:18:32:36 Gül DESKTOP-B7S3NUH PageOpen FullProgressDialog
2017/3/30:18:32:37 Gül DESKTOP-B7S3NUH Download Play STARTMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:18:32:37 Gül DESKTOP-B7S3NUH Download Complete STARTMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:18:32:37 Gül DESKTOP-B7S3NUH Download Skipped DIRECTX http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:18:32:37 Gül DESKTOP-B7S3NUH Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2018\3rdParty\DirectX\DXSETUP.exe" /silent
2017/3/30:18:32:47 Gül DESKTOP-B7S3NUH DirectX Runtime return code: 0
2017/3/30:18:32:47 Gül DESKTOP-B7S3NUH Install DirectX Runtime Succeeded
2017/3/30:18:32:47 Gül DESKTOP-B7S3NUH Download Skipped CM http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:18:32:47 Gül DESKTOP-B7S3NUH Installing Autodesk Material Library 2018: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2018" SETUP_PACKAGECODE={DD42F784-12DC-49EE-8045-600335BE940B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={D7AC923A-BC24-471F-ABC1-E578C6B5D699} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/30:18:33:07 Gül DESKTOP-B7S3NUH Install Autodesk Material Library 2018 Succeeded
2017/3/30:18:33:07 Gül DESKTOP-B7S3NUH Download Skipped CMILB http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:18:33:07 Gül DESKTOP-B7S3NUH Installing Autodesk Material Library 2018 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2018" SETUP_PACKAGECODE={DD42F784-12DC-49EE-8045-600335BE940B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={D7AC923A-BC24-471F-ABC1-E578C6B5D699} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/30:18:33:18 Gül DESKTOP-B7S3NUH Install Autodesk Material Library 2018 - Base Image Library Succeeded
2017/3/30:18:33:18 Gül DESKTOP-B7S3NUH Download Skipped CMAIL http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:18:33:19 Gül DESKTOP-B7S3NUH Installing Autodesk® Material Library 2018 - Advanced Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2018" SETUP_PACKAGECODE={DD42F784-12DC-49EE-8045-600335BE940B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{7847611E-92E9-4917-B395-71C91D523104},;;;;" PACKAGEUPI={D7AC923A-BC24-471F-ABC1-E578C6B5D699} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/30:18:33:32 Gül DESKTOP-B7S3NUH Install Autodesk® Material Library 2018 - Advanced Image Library Succeeded
2017/3/30:18:33:33 Gül DESKTOP-B7S3NUH Download Play ACAD http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:18:33:59 Gül DESKTOP-B7S3NUH Download Error ACAD <B>Connection has expired.</B>Please Install Now again from the Autodesk website. http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:18:33:59 Gül DESKTOP-B7S3NUH Download Error ACAD Unknown error! http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:18:34:00 Gül DESKTOP-B7S3NUH Download Aborted ACAD http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:18:34:00 Gül DESKTOP-B7S3NUH Install Autodesk® AutoCAD® 2018 Core Failed Download Failed, Installation aborted, Result=1603
2017/3/30:18:34:03 Gül DESKTOP-B7S3NUH Rollback Autodesk® Material Library 2018 - Advanced Image Library Succeeded
2017/3/30:18:34:15 Gül DESKTOP-B7S3NUH Rollback Autodesk Material Library 2018 - Base Image Library Succeeded
2017/3/30:18:34:34 Gül DESKTOP-B7S3NUH Rollback Autodesk Material Library 2018 Succeeded
2017/3/30:18:34:34 Gül DESKTOP-B7S3NUH Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2017/3/30:18:34:35 Gül DESKTOP-B7S3NUH PageOpen InstallCompleteDialog
2017/3/30:18:39:01 Gül DESKTOP-B7S3NUH === Setup ended ===
2017/3/30:18:46:48 Gül DESKTOP-B7S3NUH === Setup started on DESKTOP-B7S3NUH by Gül ===
2017/3/30:18:46:48 Gül DESKTOP-B7S3NUH Path_Length: 158
2017/3/30:18:46:48 Gül DESKTOP-B7S3NUH Current Directory C:\Autodesk\AutoCAD_2018_English_Win_32_64bit_Trial_en-us
2017/3/30:18:46:48 Gül DESKTOP-B7S3NUH Launch
2017/3/30:18:46:48 Gül DESKTOP-B7S3NUH CommandLine /PK 001J1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/AutoCAD_201..."
2017/3/30:18:46:48 Gül DESKTOP-B7S3NUH Current Directory C:\Users\GLDF8B~1\AppData\Local\Temp\_AIE8D3.tmp
2017/3/30:18:46:52 Gül DESKTOP-B7S3NUH === Setup ended ===
2017/3/30:18:46:50 Gül DESKTOP-B7S3NUH === Setup started on DESKTOP-B7S3NUH by Gül ===
2017/3/30:18:46:50 Gül DESKTOP-B7S3NUH Path_Length: 158
2017/3/30:18:46:50 Gül DESKTOP-B7S3NUH Current Directory C:\Users\GLDF8B~1\AppData\Local\Temp\_AIE8D3.tmp
2017/3/30:18:46:50 Gül DESKTOP-B7S3NUH Launch
2017/3/30:18:46:50 Gül DESKTOP-B7S3NUH Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:18:46:50 Gül DESKTOP-B7S3NUH Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:18:46:50 Gül DESKTOP-B7S3NUH Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\GLDF8B~1\AppData\Local\Temp\_AIE8D3.tmp\Setup\AcSetup.dll
2017/3/30:18:46:50 Gül DESKTOP-B7S3NUH Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/3/30:18:46:51 Gül DESKTOP-B7S3NUH PageOpen LaunchDialog
2017/3/30:18:47:00 Gül DESKTOP-B7S3NUH PageOpen LicenseDialog
2017/3/30:18:47:00 Gül DESKTOP-B7S3NUH PageOpen ProductInfoDialog
2017/3/30:18:47:00 Gül DESKTOP-B7S3NUH PageOpen ProductSelectionDialog2
2017/3/30:18:47:02 Gül DESKTOP-B7S3NUH PageOpen FullProgressDialog
2017/3/30:18:47:03 Gül DESKTOP-B7S3NUH Download Play STARTMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:18:47:03 Gül DESKTOP-B7S3NUH Download Complete STARTMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:18:47:04 Gül DESKTOP-B7S3NUH Download Skipped DIRECTX http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:18:47:04 Gül DESKTOP-B7S3NUH Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2018\3rdParty\DirectX\DXSETUP.exe" /silent
2017/3/30:18:47:13 Gül DESKTOP-B7S3NUH DirectX Runtime return code: 0
2017/3/30:18:47:13 Gül DESKTOP-B7S3NUH Install DirectX Runtime Succeeded
2017/3/30:18:47:13 Gül DESKTOP-B7S3NUH Download Skipped CM http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:18:47:13 Gül DESKTOP-B7S3NUH Installing Autodesk Material Library 2018: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2018" SETUP_PACKAGECODE={DD42F784-12DC-49EE-8045-600335BE940B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={D7AC923A-BC24-471F-ABC1-E578C6B5D699} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/30:18:47:33 Gül DESKTOP-B7S3NUH Install Autodesk Material Library 2018 Succeeded
2017/3/30:18:47:33 Gül DESKTOP-B7S3NUH Download Skipped CMILB http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:18:47:33 Gül DESKTOP-B7S3NUH Installing Autodesk Material Library 2018 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2018" SETUP_PACKAGECODE={DD42F784-12DC-49EE-8045-600335BE940B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={D7AC923A-BC24-471F-ABC1-E578C6B5D699} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/30:18:47:46 Gül DESKTOP-B7S3NUH Install Autodesk Material Library 2018 - Base Image Library Succeeded
2017/3/30:18:47:46 Gül DESKTOP-B7S3NUH Download Skipped CMAIL http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:18:47:46 Gül DESKTOP-B7S3NUH Installing Autodesk® Material Library 2018 - Advanced Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2018" SETUP_PACKAGECODE={DD42F784-12DC-49EE-8045-600335BE940B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{7847611E-92E9-4917-B395-71C91D523104},;;;;" PACKAGEUPI={D7AC923A-BC24-471F-ABC1-E578C6B5D699} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/30:18:47:58 Gül DESKTOP-B7S3NUH Install Autodesk® Material Library 2018 - Advanced Image Library Succeeded
2017/3/30:18:48:02 Gül DESKTOP-B7S3NUH Download Error ACAD http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/AutoCAD_201...
2017/3/30:18:48:02 Gül DESKTOP-B7S3NUH Install Autodesk® AutoCAD® 2018 Core Failed Download Failed, Installation aborted, Result=1603
2017/3/30:18:48:04 Gül DESKTOP-B7S3NUH Rollback Autodesk® Material Library 2018 - Advanced Image Library Succeeded
2017/3/30:18:48:16 Gül DESKTOP-B7S3NUH Rollback Autodesk Material Library 2018 - Base Image Library Succeeded
2017/3/30:18:48:36 Gül DESKTOP-B7S3NUH Rollback Autodesk Material Library 2018 Succeeded
2017/3/30:18:48:36 Gül DESKTOP-B7S3NUH Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2017/3/30:18:48:38 Gül DESKTOP-B7S3NUH PageOpen InstallCompleteDialog
2017/3/30:18:49:01 Gül DESKTOP-B7S3NUH === Setup ended ===
2017/3/30:19:22:26 Gül DESKTOP-B7S3NUH === Setup started on DESKTOP-B7S3NUH by Gül ===
2017/3/30:19:22:26 Gül DESKTOP-B7S3NUH Path_Length: 158
2017/3/30:19:22:26 Gül DESKTOP-B7S3NUH Current Directory C:\Autodesk\AutoCAD_2018_English_Win_32_64bit_Trial_en-us
2017/3/30:19:22:26 Gül DESKTOP-B7S3NUH Launch
2017/3/30:19:22:26 Gül DESKTOP-B7S3NUH CommandLine /PK 001J1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/AutoCAD_201..."
2017/3/30:19:22:26 Gül DESKTOP-B7S3NUH Current Directory C:\Users\GLDF8B~1\AppData\Local\Temp\_AI72E3.tmp
2017/3/30:19:22:34 Gül DESKTOP-B7S3NUH === Setup ended ===
2017/3/30:19:22:27 Gül DESKTOP-B7S3NUH === Setup started on DESKTOP-B7S3NUH by Gül ===
2017/3/30:19:22:27 Gül DESKTOP-B7S3NUH Path_Length: 158
2017/3/30:19:22:27 Gül DESKTOP-B7S3NUH Current Directory C:\Users\GLDF8B~1\AppData\Local\Temp\_AI72E3.tmp
2017/3/30:19:22:27 Gül DESKTOP-B7S3NUH Launch
2017/3/30:19:22:28 Gül DESKTOP-B7S3NUH Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:19:22:28 Gül DESKTOP-B7S3NUH Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:19:22:29 Gül DESKTOP-B7S3NUH Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\GLDF8B~1\AppData\Local\Temp\_AI72E3.tmp\Setup\AcSetup.dll
2017/3/30:19:22:29 Gül DESKTOP-B7S3NUH Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/3/30:19:22:30 Gül DESKTOP-B7S3NUH PageOpen LaunchDialog
2017/3/30:19:22:49 Gül DESKTOP-B7S3NUH PageOpen LicenseDialog
2017/3/30:19:22:49 Gül DESKTOP-B7S3NUH PageOpen ProductInfoDialog
2017/3/30:19:22:49 Gül DESKTOP-B7S3NUH PageOpen ProductSelectionDialog2
2017/3/30:19:22:57 Gül DESKTOP-B7S3NUH PageOpen FullProgressDialog
2017/3/30:19:23:00 Gül DESKTOP-B7S3NUH Download Play STARTMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:19:23:00 Gül DESKTOP-B7S3NUH Download Complete STARTMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:19:23:00 Gül DESKTOP-B7S3NUH Download Skipped VCREDIST2010SP1X86 http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:19:23:00 Gül DESKTOP-B7S3NUH Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2018\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe" /q /norestart /l C:\Users\GLDF8B~1\AppData\Local\Temp\vcredist_x86_2010.log
2017/3/30:19:23:09 Gül DESKTOP-B7S3NUH Microsoft Visual C++ 2010 SP1 Redistributable (x86) return code: 0
2017/3/30:19:23:09 Gül DESKTOP-B7S3NUH Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2017/3/30:19:23:09 Gül DESKTOP-B7S3NUH Download Skipped VCREDIST2010SP1X64 http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:19:23:09 Gül DESKTOP-B7S3NUH Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2018\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe" /q /norestart /l C:\Users\GLDF8B~1\AppData\Local\Temp\vcredist_x64_2010.log
2017/3/30:19:23:17 Gül DESKTOP-B7S3NUH Microsoft Visual C++ 2010 SP1 Redistributable (x64) return code: 0
2017/3/30:19:23:17 Gül DESKTOP-B7S3NUH Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2017/3/30:19:23:17 Gül DESKTOP-B7S3NUH Download Skipped UCRT http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:19:23:17 Gül DESKTOP-B7S3NUH Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2018\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2017/3/30:19:23:17 Gül DESKTOP-B7S3NUH Universal C Runtime (KB3118401) return code: 0
2017/3/30:19:23:17 Gül DESKTOP-B7S3NUH Install Universal C Runtime (KB3118401) Succeeded
2017/3/30:19:23:17 Gül DESKTOP-B7S3NUH Download Skipped VCREDIST2015X86 http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:19:23:17 Gül DESKTOP-B7S3NUH Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2018\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\GLDF8B~1\AppData\Local\Temp\vcredist_x86_2015.log
2017/3/30:19:23:23 Gül DESKTOP-B7S3NUH Microsoft Visual C++ 2015 Redistributable (x86) return code: 0
2017/3/30:19:23:23 Gül DESKTOP-B7S3NUH Install Microsoft Visual C++ 2015 Redistributable (x86) Succeeded
2017/3/30:19:23:23 Gül DESKTOP-B7S3NUH Download Skipped VCREDIST2015X64 http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:19:23:23 Gül DESKTOP-B7S3NUH Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2018\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\GLDF8B~1\AppData\Local\Temp\vcredist_x64_2015.log
2017/3/30:19:23:27 Gül DESKTOP-B7S3NUH Microsoft Visual C++ 2015 Redistributable (x64) return code: 0
2017/3/30:19:23:27 Gül DESKTOP-B7S3NUH Install Microsoft Visual C++ 2015 Redistributable (x64) Succeeded
2017/3/30:19:23:27 Gül DESKTOP-B7S3NUH Download Skipped DIRECTX http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:19:23:27 Gül DESKTOP-B7S3NUH Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2018\3rdParty\DirectX\DXSETUP.exe" /silent
2017/3/30:19:23:48 Gül DESKTOP-B7S3NUH DirectX Runtime return code: 0
2017/3/30:19:23:48 Gül DESKTOP-B7S3NUH Install DirectX Runtime Succeeded
2017/3/30:19:23:48 Gül DESKTOP-B7S3NUH Download Skipped CM http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:19:23:48 Gül DESKTOP-B7S3NUH Installing Autodesk Material Library 2018: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2018" SETUP_PACKAGECODE={DD42F784-12DC-49EE-8045-600335BE940B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={D7AC923A-BC24-471F-ABC1-E578C6B5D699} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/30:19:24:14 Gül DESKTOP-B7S3NUH Install Autodesk Material Library 2018 Succeeded
2017/3/30:19:24:15 Gül DESKTOP-B7S3NUH Download Skipped CMILB http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:19:24:15 Gül DESKTOP-B7S3NUH Installing Autodesk Material Library 2018 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2018" SETUP_PACKAGECODE={DD42F784-12DC-49EE-8045-600335BE940B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={D7AC923A-BC24-471F-ABC1-E578C6B5D699} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/30:19:24:34 Gül DESKTOP-B7S3NUH Install Autodesk Material Library 2018 - Base Image Library Succeeded
2017/3/30:19:24:34 Gül DESKTOP-B7S3NUH Download Skipped CMAIL http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:19:24:34 Gül DESKTOP-B7S3NUH Installing Autodesk® Material Library 2018 - Advanced Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2018" SETUP_PACKAGECODE={DD42F784-12DC-49EE-8045-600335BE940B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{7847611E-92E9-4917-B395-71C91D523104},;;;;" PACKAGEUPI={D7AC923A-BC24-471F-ABC1-E578C6B5D699} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/30:19:24:48 Gül DESKTOP-B7S3NUH Install Autodesk® Material Library 2018 - Advanced Image Library Succeeded
2017/3/30:19:24:48 Gül DESKTOP-B7S3NUH Download Play ACAD http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:19:36:54 Gül DESKTOP-B7S3NUH Download Error ACAD <B>Connection has expired.</B>Please Install Now again from the Autodesk website. http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:19:36:54 Gül DESKTOP-B7S3NUH Download Aborted ACAD http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2017/3/30:19:36:54 Gül DESKTOP-B7S3NUH Install Autodesk® AutoCAD® 2018 Core Failed Download Failed, Installation aborted, Result=1603
2017/3/30:19:36:57 Gül DESKTOP-B7S3NUH Rollback Autodesk® Material Library 2018 - Advanced Image Library Succeeded
2017/3/30:19:37:04 Gül DESKTOP-B7S3NUH Rollback Autodesk Material Library 2018 - Base Image Library Succeeded
2017/3/30:19:37:19 Gül DESKTOP-B7S3NUH Rollback Autodesk Material Library 2018 Succeeded
2017/3/30:19:37:19 Gül DESKTOP-B7S3NUH Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2017/3/30:19:37:19 Gül DESKTOP-B7S3NUH Rollback Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1619
2017/3/30:19:37:19 Gül DESKTOP-B7S3NUH Rollback Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1619
2017/3/30:19:37:19 Gül DESKTOP-B7S3NUH Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2017/3/30:19:37:19 Gül DESKTOP-B7S3NUH Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
Aradığınızı bulamadınız mı? Topluluğa sorun veya bilgilerinizi paylaşın.
